Dump Submitted: The Good, The Bad, and The Ugly Arrow 4K UHD
KingSigy
Post by KingSigy » Sun Aug 10, 2025 5:21 pm
I've submitted the dump files for both the theatrical and extended versions of The Good, The Bad, and The Ugly from Arrow. These are the UK released 4K UHD versions.
KingSigy
Re: Dump Submitted: The Good, The Bad, and The Ugly Arrow 4K UHD
Post by KingSigy » Sun Aug 10, 2025 5:24 pm
I just saw the previous thread where the public KeyDB.cfg file is available. I will be using that, but I have submitted both keys regardless.
MrPenguin
Post by MrPenguin » Sun Aug 10, 2025 5:25 pm
Meaning these match your own dumps, and the public KEYDB.cfg file works for you already?
MKB20_v82_TGTBTU_Extended_UHD_13AC.tgz
MKB20_v82_The_Good_The_Bad_And_The_Ugly_53EC.tgz
Carpet
Post by Carpet » Sun Aug 10, 2025 5:55 pm
I've got those same versions and both are ripping for me with the latest version of keydb.cfg.
MrDolby
Post by MrDolby » Fri Aug 15, 2025 10:34 am
I tried ripping the Arrow Ext. version three times, each with the same result: The copy was completed. 0 tracks were backed up. 1 failed. Anyone else?
ben_uk
Post by ben_uk » Fri Aug 15, 2025 8:01 pm
Anyone know what the 4 playlist files equate to in terms of the various cuts?
Post by dcoke22 » Fri Aug 15, 2025 10:50 pm
https://www.dvdcompare.net/comparisons/film.php?fid=57237
DISC TWO: Extended Cut (Blu-ray 4K)
* The Film (Extended Cut) (with grotto scene)
* The Film (Extended Cut) (without grotto scene)
* The Film (Extended Cut) (with extended torture scene, with grotto scene)
* The Film (Extended Cut) (with extended torture scene, without grotto scene)
ben_uk
Post by ben_uk » Sat Aug 16, 2025 4:56 am
Thanks but do you know which playlist within MakeMKV relates to which cut or is the list there denotes list within MakeMKV?
ben_uk
Post by ben_uk » Sat Aug 16, 2025 7:40 am
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t00
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t02
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t03
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t04
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t05
Do you know which is which? There appears to be 5 playlists.
