Dump Submitted: The Good, The Bad, and The Ugly Arrow 4K UHD
KingSigy
Post by KingSigy »
I've submitted the dump files for both the theatrical and extended versions of The Good, The Bad, and The Ugly from Arrow. These are the UK released 4K UHD versions.
KingSigy
Re: Dump Submitted: The Good, The Bad, and The Ugly Arrow 4K UHD
Post by KingSigy »
I just saw the previous thread where the public KeyDB.cfg file is available. I will be using that, but I have submitted both keys regardless.
MrPenguin
Post by MrPenguin »
KingSigy wrote:
Sun Aug 10, 2025 5:24 pm
Meaning these match your own dumps, and the public KEYDB.cfg file works for you already?
MKB20_v82_TGTBTU_Extended_UHD_13AC.tgz
MKB20_v82_The_Good_The_Bad_And_The_Ugly_53EC.tgz
Carpet
Post by Carpet »
I've got those same versions and both are ripping for me with the latest version of keydb.cfg.
MrDolby
Post by MrDolby »
I tried ripping the Arrow Ext. version three times, each with the same result: The copy was completed. 0 tracks were backed up. 1 failed. Anyone else?
ben_uk
Post by ben_uk »
Anyone know what the 4 playlist files equate to in terms of the various cuts?
ben_uk wrote:
Fri Aug 15, 2025 8:01 pm
https://www.dvdcompare.net/comparisons/film.php?fid=57237
DISC TWO: Extended Cut (Blu-ray 4K)
* The Film (Extended Cut) (with grotto scene)
* The Film (Extended Cut) (without grotto scene)
* The Film (Extended Cut) (with extended torture scene, with grotto scene)
* The Film (Extended Cut) (with extended torture scene, without grotto scene)
ben_uk
Post by ben_uk »
Thanks but do you know which playlist within MakeMKV relates to which cut or is the list there denotes list within MakeMKV?
ben_uk
Post by ben_uk »
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t00
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t02
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t03
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t04
THE GOOD, THE BAD & THE UGLY (Extended) - 4K UHD_t05
Do you know which is which? There appears to be 5 playlists.
hoth80
Post by hoth80 »
t00 = 2:58:43 = Grotto, no uncut torture, no extra. This is main Extended Cut version with audio commentary.
t02 = 2:55:25 = No Grotto, no uncut torture, no extra.
t03 = 2:57:17 = No Grotto, with uncut torture, no extra.
t04 = 3:00:32 = With Grotto, with uncut torture, no extra.
t05 = 3:01:57 = With Grotto, with uncut torture, with extra "Angel Eyes Arrives" and "Bones in the Desert" scene.
Last is hidden feature on disc. To access go to Special Features > Play Film with Uncut Torture Scene > Play with 'grotto' scene > Press "Right" arrow to activate hidden "...and more!" menu option.
