Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin »
Lifelove82 wrote:
Thu Aug 07, 2025 6:21 am
Any one have the tar. File to rip 4k. Cuz its not working for me?
You need to email your TGZ dump file to svq@makemkv.com. And can you also upload this file into (say) OneDrive or Google Drive, and then reply with a public download link please? This would allow people to try adding your disk to the public KEYDB.cfg file too, as well as telling everyone which disk you have... ;).
MrPenguin
Post by MrPenguin »
Mark-P wrote:
Thu Aug 07, 2025 7:57 am
Here is the dump file for High Society 4K
If that doesn't work, could you also upload your TGZ dump file into (say) OneDrive or Google Drive, and then reply with a public download link please? This would allow people to try adding your disk to the public KEYDB.cfg file.
Rojma
Post by Rojma »
keydb_helper wrote:
Thu Aug 07, 2025 3:17 am
Hey imacmike and Rojma, support for your Better Off Dead disc was added to the public keydb on July 30.
Yeah sorry. I hadn't updated my KEYDB.cfg file so MakeMKV was thinking it wasn't available yet. Once I updated it, MakeMKV was able to process it.
Mark-P
Post by Mark-P »
MrPenguin wrote:
Thu Aug 07, 2025 2:23 pm
Tried adding Keydb.cfg file to my directory and still no High Society 4K UHD. So here is a link to the dump file: https://drive.google.com/file/d/1-ovhNi ... sp=sharing
garnuts
Post by garnuts »
Here is the dump file for the new US Steelbook 4K of the new How to Train Your Dragon:
https://drive.google.com/file/d/1GkTt7F ... sp=sharing
Unit_KEY_RO.inf last modified date: 6/11/2025
Thanks for your support!
Gary
current_user_x
Post by current_user_x »
here are dumps of 3 Blurays "Grisaia Pantom Trigger TV Animation Blu-ray BOX" I tried to backup without success. Discs use AACS v82.
MakeMKV fails to decrypt the files, because the volume key is unknown. Tried to use the keyDB.cfg, without success.
Disc 1: https://drive.google.com/file/d/1kz1kHX ... drive_link
Disc 2: https://drive.google.com/file/d/1yhYHED ... drive_link
Disc 3: https://drive.google.com/file/d/1eRoAfS ... drive_link
hulahoo
Post by hulahoo »
TGZ dumps for the following new releases from Lionsgate Limited:
It Follows
High Tension
https://drive.google.com/drive/u/1/fold ... P8psWh2QJp
ReayMAX
Post by ReayMAX »
here's a bluray from cd. discs use AACS v81.
MakeMKV fails to decrypt the files, please add it, thanks
include MKB_RO.inf and MKB_RW.inf
https://drive.google.com/file/d/1E5sfzc ... sp=sharing
ReayMAX wrote:
Fri Aug 08, 2025 6:12 pm
MakeMKV has no problem with AACS v81 discs, only v82. What error are you getting? If it errors out part way through decrypting, it's not a key issue, it's something else. In this case, copy and paste your MakeMKV log window as this will help.
keydb_helper
Post by keydb_helper »
Mark-P wrote:
Fri Aug 08, 2025 2:42 am
Tried adding Keydb.cfg file to my directory and still no High Society 4K UHD. So here is a link to the dump file: ...
Hey Mark-P, thanks for providing a suitable disc dump file. The 463E variant of High Society has been added to the public keydb.
garnuts wrote:
Fri Aug 08, 2025 3:16 pm
Gary
Thanks for the new disc dump garnuts. The 8F92 variant of How to Train Your Dragon has been added to the public keydb. If you'd like to fully populate the keydb metadata could you please run FindVUK in 'ValidateDisc' mode?
current_user_x wrote:
Fri Aug 08, 2025 4:46 pm
Thanks for the disc dumps current_user_x. All three discs have been added to the public keydb.
hulahoo wrote:
Fri Aug 08, 2025 5:38 pm
It Follows
High Tension
Thanks hulahoo, the 6EA8 variant of It Follows and the 994C variant of High Tension have been added to the public keydb.
Hey ReayMAX, your disc has been added to the public keydb. I'm not sure if this will allow you to backup your disc with MakeMKV as there seems to be an unusual error occurring. As Marty noted MakeMKV should natively support MKBv81 AACS 1.0 titles, so I'd recommend creating a new thread for your disc.
ReayMAX
Post by ReayMAX »
MartyMcNuts wrote:
Fri Aug 08, 2025 11:06 pm
Sorry it's my fault, it's weird cause lats time makemkv shows it can't be decrypted for some issue, but when i try this time it can be decrypted successfully without any errors.
Anyway the problem is solved,thanks a lot.
ReayMAX
Post by ReayMAX »
keydb_helper wrote:
Sat Aug 09, 2025 1:54 am
Gary
It Follows
High Tension
garnuts
Post by garnuts »
Gary
"Thanks for the new disc dump garnuts. The 8F92 variant of How to Train Your Dragon has been added to the public keydb. If you'd like to fully populate the keydb metadata could you please run FindVUK in 'ValidateDisc' mode?"
I've never heard of "run FindVUK in 'ValidateDisc' mode".
A little googling I found in need DVDfab, or there were other references about running command level prompts which I didn't really understand.
Do you have any easy instructions on how to do this?
I've submitting several dumps to you in the past and you never requested this?
Since I downloaded and the latest keydb file and was able to rip the disk, what does this additional info provide if the disk can now be successfully ripped?
MrPenguin
Post by MrPenguin »
garnuts wrote:
Sat Aug 09, 2025 8:26 pm
SamuriHL's "KEYDB Helper" tool is a handy front-end for FindVUK, and should allow you to run "ValidateDisc" easily.
This mode verifies that an entry in KEYDB.cfg does indeed decrypt the physical disk in your drive, and therefore allows KEYDB to remove the entry's "(NOTVALIDATED)" tag. It also allows kEYDB to fill in any missing fields, which could not be populated using the TGZ dump file alone.
reignbo
Post by reignbo »
