You may need to explain to me exactly what you mean about powering down a drive then as I unplugged the drive for ~10 seconds which strikes me as "good enough" but if it takes several minutes for anything to hold a charge I can try that again. It'd seem odd that it would immediately work on a non-UHD encrypted bluray if the LibreDrive was failing as that did work (it failed on the UHD version of La Haine then worked on the HD version) but I can attempt it later when I have time by just unplugging it overnight.keydb_helper wrote: ↑Fri Aug 01, 2025 1:30 pmDid you actually completely power down the drive? Reflashing a drive which has previously worked with MakeMKV is never productive.raincollector123 wrote: ↑Fri Aug 01, 2025 4:53 amAs a note I see the same "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" as above but I see that even with power cycling. I also tried to reflash just to see if that fixed it and it still shows up although I didn't remove it from power afterwards so maybe? Also saw it with a different UHD but regular blu-rays are fine.
As soon as you see the error message "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" you can just delete the generated disc dump files as they are useless.
Public KeyDB Disc Submissions
Here is my dump of German UHD, hope you can help to decrypt.
MKB21_v70_Zombieland_0C04
Thank You
https://drive.google.com/file/d/1OIKoR ... share_link
Thank You
Hey kevin040474, thank you for generating a new disc dump file. Could you please enable public access to that file?kevin040474 wrote: ↑Sun Aug 03, 2025 1:55 amHere is a new dump file of the movie using lg drive not pioneer thanks for any help
You had the right idea by physically disconnecting the drive and 10 seconds is normally plenty of time for the drive to reset. It might be worth creating a thread in the MakeMKV Linux subforum to try to get to the bottom of your UHD/LibreDrive issue. If you have access to a Windows or macOS computer it would also be worth trying to confirm the issue is specific to your Linux system and not the drive.raincollector123 wrote: ↑Sun Aug 03, 2025 3:15 amYou may need to explain to me exactly what you mean about powering down a drive then as I unplugged the drive for ~10 seconds which strikes me as "good enough" but if it takes several minutes for anything to hold a charge I can try that again. It'd seem odd that it would immediately work on a non-UHD encrypted bluray if the LibreDrive was failing as that did work (it failed on the UHD version of La Haine then worked on the HD version) but I can attempt it later when I have time by just unplugging it overnight.
It is important to remember that even when LibreDrive is not working MakeMKV can still process most AACS 1.0 (1080p) Blu-ray discs as it can use the standard mode of AACS authentication.
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Here's the dump of The Martian Extended Edition 587F
https://mega.nz/folder/dZRR2ZLQ#InBP7CLlwS099L2eeQEAng
Here's the dump for Sunset Boulevard UHD.
https://drive.google.com/file/d/1Lq1hQ1 ... sp=sharing
Thanks AnBird, the 587F variant of The Martian has been added to the public keydb.
Hey lolipeid47, thanks for providing a suitable disc dump file. The A874 variant of Warfare has been added to the public keydb.lolipeid47 wrote: ↑Mon Aug 04, 2025 7:49 pmHello,
Here is my dump, I'm stuck with it since 7 days, so happy to find this thread after some intensive research![]()
UHD FRA - MKB20_v82_Warfare_A874
Dump created with ASUS 16D1-HT
Happy winter could be more relevant...lolipeid47 wrote: ↑Mon Aug 04, 2025 7:49 pmBig love and happy summer to the person that will find the VUK.![]()
Thanks for the disc dump baelon. Your variant of Sunset Boulevard was added to the public keydb on July 31. Follow the instructions I linked in the first post of this thread and you'll be able to decrypt your disc.
Thanks for the disc dump hulahoo. The 0702 variant of Convoy has been added to the public keydb.
Hey Toad King, thanks for the new disc dump. The E53A variant of Wolf Children has been added to the public keydb.
Dump for Daybreakers UHD
MKB20_v82_Daybreakers_UHD_878E.tgz
https://drive.google.com/file/d/1SraeJr ... p=drivesdk
MKB_RO.zip
https://drive.google.com/file/d/1vZzofu ... p=drivesdk
MKB_RO.zip
Hey mattmak464, thank you for providing a suitable disc dump file. The 878E variant of Daybreakers has been added to the public keydb.mattmak464 wrote: ↑Wed Aug 06, 2025 10:23 amDump for Daybreakers UHD
here are 2 dumps of the new The Good, The Bad and The Ugly release by Arrow. (Blu-Ray Version)
https://drive.google.com/file/d/1TBftSJ ... drive_link
https://drive.google.com/file/d/1V8akov ... drive_link
Thank you.
Thank you.
Can you adjust this file's "Sharing" option please, so that people can access them? (These two links are the same, btw. Did you have 2 dumps?)
Thanks, but those two dumps still look like they are for the same disk. Do you have two disks?
