Dump Warfare EU (Dutch Release)
Can't open de disc. Here's the dump
- MKB20_v82_Warfare_A874.tgz
- (3.27 MiB) Downloaded 360 times
Re: Dump Warfare EU (Dutch Release)
You appear to have created this dump using a Verbatim 43888 drive containing a Pioneer BDR-UD04 device. Would you also happen to have access to a non-Pioneer UHD drive please? Your particular Verbatim creates dumps that are only really usable by MakeMKV itself, and not by KEYDB.
Hi!MrPenguin wrote: Wed Jul 30, 2025 11:55 amYou appear to have created this dump using a Verbatim 43888 drive. Would you also happen to have access to a non-Pioneer UHD drive please? Your particular Verbatim creates dumps that are only really usable by MakeMKV itself, and not by KEYDB.
Sadly i dont have any other drive. This is the only one i have.
So long as you have also emailed your dump file to svq@makemkv.com, MakeMKV will still be able to decrypt your disk.Chozx wrote: Wed Jul 30, 2025 11:56 am Sadly i dont have any other drive. This is the only one i have.
I will mail it!MrPenguin wrote: Wed Jul 30, 2025 3:31 pmSo long as you have also emailed your dump file to svq@makemkv.com, MakeMKV will still be able to decrypt your disk.Chozx wrote: Wed Jul 30, 2025 11:56 am Sadly i dont have any other drive. This is the only one i have.
The problem is that it goes straight to the begin screen and i won’t have option to select options. The blu-ray disc works perfectly
Email in the dump then wait about a week for MakeMKV to add support for it.Chozx wrote: Wed Jul 30, 2025 3:52 pmI will mail it!MrPenguin wrote: Wed Jul 30, 2025 3:31 pmSo long as you have also emailed your dump file to svq@makemkv.com, MakeMKV will still be able to decrypt your disk.Chozx wrote: Wed Jul 30, 2025 11:56 am Sadly i dont have any other drive. This is the only one i have.
Thanks! i've emailed it yesterday. Now the waiting beginsMartyMcNuts wrote: Thu Jul 31, 2025 2:33 amEmail in the dump then wait about a week for MakeMKV to add support for it.Chozx wrote: Wed Jul 30, 2025 3:52 pmI will mail it!MrPenguin wrote: Wed Jul 30, 2025 3:31 pm
Yep, just stick the disc in every few days and see if you can rip it.Chozx wrote: Thu Jul 31, 2025 8:44 amThanks! i've emailed it yesterday. Now the waiting beginsMartyMcNuts wrote: Thu Jul 31, 2025 2:33 amEmail in the dump then wait about a week for MakeMKV to add support for it.Chozx wrote: Wed Jul 30, 2025 3:52 pm
I will mail it!
The problem is that it goes straight to the begin screen and i won’t have option to select options. The blu-ray disc works perfectly![]()
Thanks for the help all!MartyMcNuts wrote: Thu Jul 31, 2025 10:14 amYep, just stick the disc in every few days and see if you can rip it.Chozx wrote: Thu Jul 31, 2025 8:44 amThanks! i've emailed it yesterday. Now the waiting beginsMartyMcNuts wrote: Thu Jul 31, 2025 2:33 am
Email in the dump then wait about a week for MakeMKV to add support for it.![]()
Hi, my dump, same id but french cover.
TGZ :
https://drive.google.com/file/d/1pwfSei ... sp=sharing
ZIP :
https://drive.google.com/file/d/1AAYxoi ... sp=sharing
TGZ :
ZIP :
Key Add Thx
