tried to backup UHD Mission Impossible Dead Reckoning Part 1 and it failed - German version
Dump of Mission Impossible Dead Reckoning Part 1
- MKB20_v77_MI_DEAD_RECKONING_PART_1_302B.tgz
- (229.2 KiB) Downloaded 139 times
Re: Dump of Mission Impossible Dead Reckoning Part 1
Thanks for this dump file. Would you also happen to have access to a non-Pioneer UHD drive please? Your Verbatim 43888 drive writes some of its MakeMKV metadata such that only MakeMKV itself can read it.
And could you also provide the (zipped!) actual AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside the TGZ dump file has been truncated to only 56 bytes, which also makes it unusable to anyone except MakeMKV. This file is almost certainly too large to attach here, and so the preferred solution would be to upload it into a file host like Google Drive or OneDrive, and then reply with a public download link.
thank you and sorry I have no other drive in access. But here is the missing file from BluRay
Hmm, no file here. Could you check your PM please?
Keine Datei vorhanden. Vielleicht war sie zu groß zum Anhängen? Sie müssten sie zuerst komprimieren, um sie zu verkleinern.
strange I had added and it was green. Anyhow I sent via email as requested. I could not answer your PM.
Thanks for support.
Thanks for support.
Thanks, this forum doesn't allow people to use PMs until they've posted publicly for three or more times.
