Public KeyDB Disc Submissions
kevin040474
Post by kevin040474 » Sun Aug 03, 2025 1:55 am
MrPenguin wrote: Fri Aug 01, 2025 10:03 am
kevin040474 wrote: Fri Aug 01, 2025 12:15 am MKB20_v82_SINNERS_9F22.tgz
Thanks for providing this dump file. You appear to have created it using a Verbatim 43888 drive containing a Pioneer BDR-UD04 device, which makes some of its information unreadable by anyone except MakeMKV itself. Would you happen to have access to a non-Pioneer UHD drive please?
Here is a new dump file of the movie using lg drive not pioneer thanks for any help
https://drive.google.com/file/d/1t_VO0n ... drive_link
raincollector123
Post by raincollector123 » Sun Aug 03, 2025 3:15 am
keydb_helper wrote: Fri Aug 01, 2025 1:30 pm
raincollector123 wrote: Fri Aug 01, 2025 4:53 am As a note I see the same "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" as above but I see that even with power cycling. I also tried to reflash just to see if that fixed it and it still shows up although I didn't remove it from power afterwards so maybe? Also saw it with a different UHD but regular blu-rays are fine.
Did you actually completely power down the drive? Reflashing a drive which has previously worked with MakeMKV is never productive.
As soon as you see the error message "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" you can just delete the generated disc dump files as they are useless.
You may need to explain to me exactly what you mean about powering down a drive then as I unplugged the drive for ~10 seconds which strikes me as "good enough" but if it takes several minutes for anything to hold a charge I can try that again. It'd seem odd that it would immediately work on a non-UHD encrypted bluray if the LibreDrive was failing as that did work (it failed on the UHD version of La Haine then worked on the HD version) but I can attempt it later when I have time by just unplugging it overnight.
Mythbuster
Post by Mythbuster » Sun Aug 03, 2025 8:50 am
Here is my dump of German UHD, hope you can help to decrypt.
MKB21_v70_Zombieland_0C04
Thank You
https://drive.google.com/file/d/1OIKoR ... share_link
keydb_helper
Post by keydb_helper » Sun Aug 03, 2025 10:07 am
kevin040474 wrote: Sun Aug 03, 2025 1:55 am Here is a new dump file of the movie using lg drive not pioneer thanks for any help
Hey kevin040474, thank you for generating a new disc dump file. Could you please enable public access to that file?
raincollector123 wrote: Sun Aug 03, 2025 3:15 am You may need to explain to me exactly what you mean about powering down a drive then as I unplugged the drive for ~10 seconds which strikes me as "good enough" but if it takes several minutes for anything to hold a charge I can try that again. It'd seem odd that it would immediately work on a non-UHD encrypted bluray if the LibreDrive was failing as that did work (it failed on the UHD version of La Haine then worked on the HD version) but I can attempt it later when I have time by just unplugging it overnight.
You had the right idea by physically disconnecting the drive and 10 seconds is normally plenty of time for the drive to reset. It might be worth creating a thread in the MakeMKV Linux subforum to try to get to the bottom of your UHD/LibreDrive issue. If you have access to a Windows or macOS computer it would also be worth trying to confirm the issue is specific to your Linux system and not the drive.
It is important to remember that even when LibreDrive is not working MakeMKV can still process most AACS 1.0 (1080p) Blu-ray discs as it can use the standard mode of AACS authentication.
KeyDB Download
AnBird
Post by AnBird » Mon Aug 04, 2025 6:28 pm
Here's the dump of The Martian Extended Edition 587F
https://mega.nz/folder/dZRR2ZLQ#InBP7CLlwS099L2eeQEAng
lolipeid47
Post by lolipeid47 » Mon Aug 04, 2025 7:49 pm
baelon
Post by baelon » Tue Aug 05, 2025 4:09 pm
Here's the dump for Sunset Boulevard UHD.
https://drive.google.com/file/d/1Lq1hQ1 ... sp=sharing
hulahoo
Post by hulahoo » Tue Aug 05, 2025 6:50 pm
Toad King
Post by Toad King » Tue Aug 05, 2025 7:17 pm
keydb_helper
Post by keydb_helper » Tue Aug 05, 2025 11:39 pm
AnBird wrote: Mon Aug 04, 2025 6:28 pm Here's the dump of The Martian Extended Edition 587F
Thanks AnBird, the 587F variant of The Martian has been added to the public keydb.
lolipeid47 wrote: Mon Aug 04, 2025 7:49 pm Hello,
Here is my dump, I'm stuck with it since 7 days, so happy to find this thread after some intensive research :D
UHD FRA - MKB20_v82_Warfare_A874
Dump created with ASUS 16D1-HT
Hey lolipeid47, thanks for providing a suitable disc dump file. The A874 variant of Warfare has been added to the public keydb.
lolipeid47 wrote: Mon Aug 04, 2025 7:49 pm Big love and happy summer to the person that will find the VUK. :wink:
Happy winter could be more relevant...
baelon wrote: Tue Aug 05, 2025 4:09 pm Hi,
Thanks for the disc dump baelon. Your variant of Sunset Boulevard was added to the public keydb on July 31. Follow the instructions I linked in the first post of this thread and you'll be able to decrypt your disc.
hulahoo wrote: Tue Aug 05, 2025 6:50 pm TGZ dump for Convoy 4K UHD
Thanks for the disc dump hulahoo. The 0702 variant of Convoy has been added to the public keydb.
Toad King wrote: Tue Aug 05, 2025 7:17 pm Dump for Wolf Children
Hey Toad King, thanks for the new disc dump. The E53A variant of Wolf Children has been added to the public keydb.
KeyDB Download
mattmak464
Post by mattmak464 » Wed Aug 06, 2025 10:23 am
Dump for Daybreakers UHD
MKB20_v82_Daybreakers_UHD_878E.tgz
https://drive.google.com/file/d/1SraeJr ... p=drivesdk
MKB_RO.zip
https://drive.google.com/file/d/1vZzofu ... p=drivesdk
keydb_helper
Post by keydb_helper » Wed Aug 06, 2025 10:39 am
mattmak464 wrote: Wed Aug 06, 2025 10:23 am Dump for Daybreakers UHD
Hey mattmak464, thank you for providing a suitable disc dump file. The 878E variant of Daybreakers has been added to the public keydb.
KeyDB Download
Jubo30
Post by Jubo30 » Wed Aug 06, 2025 6:37 pm
here are 2 dumps of the new The Good, The Bad and The Ugly release by Arrow. (Blu-Ray Version)
https://drive.google.com/file/d/1TBftSJ ... drive_link
https://drive.google.com/file/d/1V8akov ... drive_link
Thank you.
MrPenguin
Post by MrPenguin » Wed Aug 06, 2025 7:02 pm
Jubo30 wrote: Wed Aug 06, 2025 6:37 pm here are 2 dumps of the new The Good, The Bad and The Ugly release by Arrow. (Blu-Ray Version)
Can you adjust this file's "Sharing" option please, so that people can access them? (These two links are the same, btw. Did you have 2 dumps?)
Jubo30
Post by Jubo30 » Wed Aug 06, 2025 7:09 pm
MrPenguin wrote: Wed Aug 06, 2025 7:02 pm
Sorry, my bad. It should be fixed and open for everyone now, after the mods clear it.
