Hi CJT80,CJT80 wrote: Thu Jul 31, 2025 4:51 pmJust wanted to update you and say how impressed I am with the new drive! My only "criticism" is the length of the cable from the provided UK Plug Adaptor, it is very short. I have e-mailed Asmcom for any suggestions on if I can use an extension cable from the barrel jack to extend it's cable length. I am not sure what I would need as I am unfamiliar with barrel jack supplies. If anyone has the above BD Drive with the power adaptor from the UK and knows an appropriate extension cable please reply or message me directly.CJT80 wrote: Fri Jul 25, 2025 4:30 pm Just a quick update.
After a brief e-mail chat with Asmcom I have ordered the Pioneer BDR-XS07TUHD with power supply and case at a very nicely discounted price via the link on here. I also opted for the lifetime licence for MakeMKV.
I have been provided with a tracking reference for Royal Mail and now all I have to do is wait delivery.
I will post again once I have used the drive.![]()
Once again overall I am very happy with the purchase!![]()
Thank you so much for the kind feedback. We’re delighted to hear you're happy with your new Pioneer BDR-XS07TUHD setup!
Regarding the power adapter we supplied, we completely understand your concern. The unit we supply uses what we’ve found to be the most reliable and safest power supply available, which we have extensively tested. Unfortunately, the barrel jack cable length is limited to approximately 90cm. We're sorry it’s not quite long enough for your setup.
That said, if you’re looking for a longer cable, we’ve found a suitable 1.5-metre power supply on eBay that’s compatible with the drive and uses the same 12V/2A DC barrel connector. Please note, however, that it is quite expensive at $53.76 plus postage:
https://www.ebay.co.uk/itm/226856346877
Thanks again for your support and feedback, it’s always appreciated!
Kind regards,
Asmcom
UHD Friendly Drives Team
