Failed to open disc.
NatalyaI684
Post by NatalyaI684 »
Hello everyone.
I bought the VERBATIM 43888
Ultra HD 4K External Slimline Blu-ray Writer
USB 3.2 Gen 1 with USB-Ctm Connection
I tried to extract the film Blu Ray 4K UHD "Through the Looking Glass (1976)".
I found the following error:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\ALL/.MakeMKV/MKB20_v77_MEL-003UHD_4059.tgz
Here's the info…
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO7OB1B1258
Highest AACS version: 81
Disc Information
Label: MEL-003UHD
Timestamp: 2024-09-11 19:40:16
Protection: AACS2.0/C v77
Data capacity: 61.11 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Please could someone kindly help me with this ?
MrPenguin
Re: Failed to open disc.
Post by MrPenguin »
NatalyaI684 wrote: Thu Jul 31, 2025 9:20 am LibreDrive Information
You're going to need to flash your's drive's firmware to enable LibreDrive before MakeMKV can handle your UHD disk.
The drive needs to be flashed to support LibreDrive before it will rip 4K UHDs. Fortunately, since your drive is a BU40N it is fairly easy and straightforward to do. The Ultimate UHD Drives Flashing Guide has instructions and links to the SDFtool Flasher and the firmware needed. The guide recommends:
BU40N on any Firmware directly to > BU40N 1.03MK
NatalyaI684
Thank you for helping me.
I am a novice in computer science.
The flasher sdftool tool seems easy to use but I do not understand which steps to flash the firmware
and which bin file to choose.
NatalyaI684 wrote: Thu Jul 31, 2025 2:23 pm Thank you for helping me.
dcoke22 told you everything. So follow his advice.
NatalyaI684
Hello and thank you all!
Successful operation thanks to your indications.
Thank you and have a good day.
