Dump Warfare EU (Dutch Release)
Chozx
#1 Post by Chozx » Wed Jul 30, 2025 11:09 am
Can't open de disc. Here's the dump
MKB20_v82_Warfare_A874.tgz
(3.27 MiB) Downloaded 382 times
MrPenguin
Re: Dump Warfare EU (Dutch Release)
#2 Post by MrPenguin » Wed Jul 30, 2025 11:55 am
Chozx wrote: Wed Jul 30, 2025 11:09 am Can't open de disc. Here's the dump
You appear to have created this dump using a Verbatim 43888 drive containing a Pioneer BDR-UD04 device. Would you also happen to have access to a non-Pioneer UHD drive please? Your particular Verbatim creates dumps that are only really usable by MakeMKV itself, and not by KEYDB.
Chozx
#3 Post by Chozx » Wed Jul 30, 2025 11:56 am
MrPenguin wrote: Wed Jul 30, 2025 11:55 am
You appear to have created this dump using a Verbatim 43888 drive. Would you also happen to have access to a non-Pioneer UHD drive please? Your particular Verbatim creates dumps that are only really usable by MakeMKV itself, and not by KEYDB.
Hi!
Sadly i dont have any other drive. This is the only one i have.
MrPenguin
#4 Post by MrPenguin » Wed Jul 30, 2025 3:31 pm
Chozx wrote: Wed Jul 30, 2025 11:56 am Sadly i dont have any other drive. This is the only one i have.
So long as you have also emailed your dump file to svq@makemkv.com, MakeMKV will still be able to decrypt your disk.
Chozx
#5 Post by Chozx » Wed Jul 30, 2025 3:52 pm
MrPenguin wrote: Wed Jul 30, 2025 3:31 pm
I will mail it!
The problem is that it goes straight to the begin screen and i won’t have option to select options. The blu-ray disc works perfectly
#6 Post by MartyMcNuts » Thu Jul 31, 2025 2:33 am
Chozx wrote: Wed Jul 30, 2025 3:52 pm
I will mail it!
Email in the dump then wait about a week for MakeMKV to add support for it.
Chozx
#7 Post by Chozx » Thu Jul 31, 2025 8:44 am
MartyMcNuts wrote: Thu Jul 31, 2025 2:33 am
I will mail it!
Thanks! i've emailed it yesterday. Now the waiting begins ;)
#8 Post by MartyMcNuts » Thu Jul 31, 2025 10:14 am
Chozx wrote: Thu Jul 31, 2025 8:44 am
I will mail it!
Yep, just stick the disc in every few days and see if you can rip it.
Chozx
#9 Post by Chozx » Thu Jul 31, 2025 1:37 pm
MartyMcNuts wrote: Thu Jul 31, 2025 10:14 am
Thanks for the help all!
Fu2chN
#10 Post by Fu2chN » Tue Aug 05, 2025 5:17 pm
Fu2chN
#11 Post by Fu2chN » Wed Aug 06, 2025 4:45 am
Key Add Thx
