Dump Submitted - Barry Lyndon
MKB20_v82_BARRY_LYNDON_8C5E
KeyDB works in the meantime.
Re: Dump Submitted - Barry Lyndon
Anyone else having issues with KeyDB?
I've just submitted the dump for Criterion's 4K disc too.
We demand satisfaction!
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?
If this doesn't work, could you also make this TGZ dump file available here please, e.g. by uploading it into (say) OneDrive or Google Drive, and then providing a public download link? This would allow people to try adding your disk to the public KEYDB file.
See Public KEYDB Disc Submissions.
I have been trying to rip this 4K video for more than a week. Has anyone been able to rip it? Thanks.
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Elephen wrote: Thu Jul 17, 2025 11:27 pm I have been trying to rip this 4K video for more than a week. Has anyone been able to rip it? Thanks.
Yes. I tried using lower case letters and upper case letters for the file name. When I downloaded the file, it was not zipped, so there was nothing to extract as mentioned in the instruction. My current drive is a Pioneer, which replaced my original LG drive.
AFAIK the latest KEYDB.cfg file does contain the 8C5E variant of this disk. Do you have a different variant? And if so, perhaps provide your TGZ dump file here please?Elephen wrote: Thu Jul 17, 2025 11:36 pm Yes. I tried using lower case letters and upper case letters for the file name. When I downloaded the file, it was not zipped, so there was nothing to extract as mentioned in the instruction. My current drive is a Pioneer, which replaced my original LG drive.
I hope this helps.
MKB20_v82_BARRY_LYNDON_8084.tgz
Can you upload that file into (say) OneDrive or Google Drive please, and then reply with a public download link? And also email it to svq@makemkv.com, of course.
I emailed the link to svq@makemkv.com on day 1. Unfortunately, I have never used OneDrive or Google Drive.
I tried when I first came here (dah forums)
I will try again.
to clarify I drop in in the same directory that the DUMPS occur.
like for me its a data directory like this.
C:\Users\<username>\.MakeMKV
originally I read in the directory the binaries are installed.
Then I read the directry the dumps get spit.
Still failed?
Should I be uploading multiple dumps?
oe wait a bit and check the thread?
I will try again.
Still failed?
You extract the KeyDB.cfg file from the zip file to the MakeMKV data directory (where the dumps are).cbuteau wrote: Wed Jul 30, 2025 8:38 pm I tried when I first came here (dah forums)
I will try again.
Still failed?
