Dump Warfare EU (Dutch Release)
Chozx
Post by Chozx »
Can't open de disc. Here's the dump
MrPenguin
Re: Dump Warfare EU (Dutch Release)
Post by MrPenguin »
Chozx wrote: Wed Jul 30, 2025 11:09 am Can't open de disc. Here's the dump
You appear to have created this dump using a Verbatim 43888 drive containing a Pioneer BDR-UD04 device. Would you also happen to have access to a non-Pioneer UHD drive please? Your particular Verbatim creates dumps that are only really usable by MakeMKV itself, and not by KEYDB.
Chozx
Post by Chozx »
MrPenguin wrote: Wed Jul 30, 2025 11:55 am
You appear to have created this dump using a Verbatim 43888 drive. Would you also happen to have access to a non-Pioneer UHD drive please? Your particular Verbatim creates dumps that are only really usable by MakeMKV itself, and not by KEYDB.
Hi!
Sadly i dont have any other drive. This is the only one i have.
MrPenguin
Post by MrPenguin »
Chozx wrote: Wed Jul 30, 2025 11:56 am Sadly i dont have any other drive. This is the only one i have.
So long as you have also emailed your dump file to svq@makemkv.com, MakeMKV will still be able to decrypt your disk.
Chozx
Post by Chozx »
MrPenguin wrote: Wed Jul 30, 2025 3:31 pm
I will mail it!
The problem is that it goes straight to the begin screen and i won’t have option to select options. The blu-ray disc works perfectly
Chozx wrote: Wed Jul 30, 2025 3:52 pm
I will mail it!
Email in the dump then wait about a week for MakeMKV to add support for it.
Chozx
Post by Chozx »
MartyMcNuts wrote: Thu Jul 31, 2025 2:33 am
I will mail it!
Thanks! i've emailed it yesterday. Now the waiting begins ;)
Chozx wrote: Thu Jul 31, 2025 8:44 am
I will mail it!
Yep, just stick the disc in every few days and see if you can rip it.
Chozx
Post by Chozx »
MartyMcNuts wrote: Thu Jul 31, 2025 10:14 am
Thanks for the help all!
Fu2chN
Post by Fu2chN »
Fu2chN
Post by Fu2chN »
Key Add Thx
