Marvel's Thunderbolts* TGZ Key File
MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_C590.tgz
Drive File Link:
https://drive.google.com/file/d/1Uk30OK ... drive_link
lemme know if you need help getting the file out, should be open
Dump Submitted - Thunderbolts* 4K UHD
FootFungus07
Re: Dump Submitted - Thunderbolts* 4K UHD
Just in case this helps.
I just submitted my dump file:
MKB20_v82_MARVEL_STUDIOS'_THUNDERBOLTS_E856
Could you also upload this file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too.
ThunderboltsMrPenguin wrote: Wed Jul 23, 2025 5:58 pmCould you also upload this file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too.
tjparasite
Thunderbolts,
I believe this is a different dump, my apologies if it is a duplicate:
MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
Emailed Dump file
Emailed Dump file
dawg_ripper
Thanks, 607C is the one I just got in the mail.
GrantSurewood
Not Sure if this helps: MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
https://drive.google.com/file/d/1QmvSfK ... sp=sharing
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?GrantSurewood wrote: Tue Jul 29, 2025 9:56 pm Not Sure if this helps: MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
cybergrimes
