Queer (2024) Dump submitted
mczocker32
MKB20_v82_MUBIDE008U_459E
MrPenguin
Re: Queer (2024) Dump submitted
If this doesn't work, then maybe upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
mczocker32
I download the KEYDB via cronjob every hour so it shouldn’t be there unless added between the two syncs.MrPenguin wrote: Tue Jul 29, 2025 12:04 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
keydb_helper
The 459E variant of Queer has been added to the public keydbmczocker32 wrote: Tue Jul 29, 2025 12:11 pm I download the KEYDB via cronjob every hour so it shouldn’t be there unless added between the two syncs.
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
