Queer (2024) Dump submitted
mczocker32
Post by mczocker32 »
MKB20_v82_MUBIDE008U_459E
MrPenguin
Re: Queer (2024) Dump submitted
Post by MrPenguin »
mczocker32 wrote:
Tue Jul 29, 2025 11:54 am
If this doesn't work, then maybe upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
mczocker32
MrPenguin wrote:
Tue Jul 29, 2025 12:04 pm
I download the KEYDB via cronjob every hour so it shouldn’t be there unless added between the two syncs.
keydb_helper
Post by keydb_helper »
mczocker32 wrote:
Tue Jul 29, 2025 12:11 pm
The 459E variant of Queer has been added to the public keydb
Public KeyDB Disc Submissions
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
