AACS v82 dump - BRMM-10913
headroom6657
#1 Post by headroom6657 » Thu May 01, 2025 9:58 am
Had issues ripping the newly released blu-rays with AACS v82 encryption using MakeMKV v1.18.1.
I've attached the dump here and also emailed svq@makemkv.com for good measure.
Any help on this would be greatly appreciated.
Thanks a lot!
MKB_v82_MyGO!!!!!_6th_Single「聿日箋秋」【Blu-ray付生産限定盤】DISC1_5252.tgz
(91.2 KiB) Downloaded 1023 times
MKB_v82_MyGO!!!!!_6th_Single「聿日箋秋」【Blu-ray付生産限定盤】DISC2_0834.tgz
(55.46 KiB) Downloaded 971 times
MrPenguin
Re: AACS v82 dump - BRMM-10913
#2 Post by MrPenguin » Thu May 01, 2025 1:49 pm
#3 Post by MartyMcNuts » Thu May 01, 2025 11:39 pm
Thanks a lot!
The discatt.dat files contained in your dumps do not appear to be valid. They are missing alot of information.
headroom6657
#4 Post by headroom6657 » Sun May 04, 2025 6:08 am
Hi! Apologies for the late reply.
Just tried this and it is now ripping properly. Thanks again for the help!
mimimi
#5 Post by mimimi » Thu Jul 24, 2025 1:52 pm
こんにちは。日本からの投稿です。
このBlu-rayディスク(タイトル:THE VERY BEST OF FANTASY NARITA THOMAS SIMPSON)は、MakeMKVで「このディスクはサポートされていません」と表示されましたので、v82のダンプファイルを添付します。対応よろしくお願いいたします。
Hi, I'm posting from Japan.
This Blu-ray disc (Title: THE VERY BEST OF FANTASY NARITA THOMAS SIMPSON) shows "This disc is not supported" in MakeMKV.
I'm attaching the AACS v82 dump file.
Please add support for this disc. Thank you!
Title: Narita Thomas Simpson
Region: A
Country: Japan
MakeMKV version: 1.18.1
File attached: MKB_v82_NTS_20241225_BD_DD50.tgz
(101.92 KiB) Downloaded 10 times
#6 Post by MartyMcNuts » Fri Jul 25, 2025 2:10 am
こんにちは。日本からの投稿です。
Region: A
Country: Japan
Did you email the dump file to svq@makemkv.com?? If not, please do so otherwise MakeMKV will not be able to add support for it!
geissd
#7 Post by geissd » Fri Jul 25, 2025 8:46 pm
I also tried to download the newest keydb.cfg and copied it into the data folder "C:\Users\<YourUsername>\.MakeMKV". Then I restarted MakeMKV.exe. Same problem again.
#8 Post by MartyMcNuts » Sat Jul 26, 2025 2:54 am
Did you extract the KeyDB.cfg from the zip file?
mimimi
#9 Post by mimimi » Sat Jul 26, 2025 11:05 am
さきほどメールでもダンプファイルを送信いたしました。
ご確認をおねがいいたします。
こんにちは。日本からの投稿です。
Region: A
Country: Japan
