AACS v82 dump - BRMM-10913
headroom6657
Post by headroom6657 »
Had issues ripping the newly released blu-rays with AACS v82 encryption using MakeMKV v1.18.1.
I've attached the dump here and also emailed svq@makemkv.com for good measure.
Any help on this would be greatly appreciated.
Thanks a lot!
MKB_v82_MyGO!!!!!_6th_Single「聿日箋秋」【Blu-ray付生産限定盤】DISC1_5252.tgz
(91.2 KiB) Downloaded 1149 times
MKB_v82_MyGO!!!!!_6th_Single「聿日箋秋」【Blu-ray付生産限定盤】DISC2_0834.tgz
(55.46 KiB) Downloaded 1058 times
MrPenguin
Re: AACS v82 dump - BRMM-10913
Post by MrPenguin »
headroom6657 wrote:
Thu May 01, 2025 9:58 am
Thanks a lot!
The discatt.dat files contained in your dumps do not appear to be valid. They are missing alot of information.
headroom6657
MrPenguin wrote:
Thu May 01, 2025 1:49 pm
Hi! Apologies for the late reply.
Just tried this and it is now ripping properly. Thanks again for the help!
mimimi
Post by mimimi »
こんにちは。日本からの投稿です。
このBlu-rayディスク(タイトル:THE VERY BEST OF FANTASY NARITA THOMAS SIMPSON)は、MakeMKVで「このディスクはサポートされていません」と表示されましたので、v82のダンプファイルを添付します。対応よろしくお願いいたします。
Hi, I'm posting from Japan.
This Blu-ray disc (Title: THE VERY BEST OF FANTASY NARITA THOMAS SIMPSON) shows "This disc is not supported" in MakeMKV.
I'm attaching the AACS v82 dump file.
Please add support for this disc. Thank you!
Title: Narita Thomas Simpson
Region: A
Country: Japan
MakeMKV version: 1.18.1
File attached: MKB_v82_NTS_20241225_BD_DD50.tgz
(101.92 KiB) Downloaded 117 times
mimimi wrote:
Thu Jul 24, 2025 1:52 pm
こんにちは。日本からの投稿です。
Region: A
Country: Japan
Did you email the dump file to svq@makemkv.com?? If not, please do so otherwise MakeMKV will not be able to add support for it!
geissd
Post by geissd »
headroom6657 wrote:
Sun May 04, 2025 6:08 am
I also tried to download the newest keydb.cfg and copied it into the data folder "C:\Users\<YourUsername>\.MakeMKV". Then I restarted MakeMKV.exe. Same problem again.
geissd wrote:
Fri Jul 25, 2025 8:46 pm
Did you extract the KeyDB.cfg from the zip file?
mimimi
Post by mimimi »
さきほどメールでもダンプファイルを送信いたしました。
ご確認をおねがいいたします。
こんにちは。日本からの投稿です。
Region: A
Country: Japan
