Public KeyDB Disc Submissions
SamuriHL wrote:
Fri Jul 25, 2025 2:14 am
MartyMcNuts wrote:
Fri Jul 25, 2025 2:04 am
SamuriHL wrote:
Fri Jul 25, 2025 1:24 am
Make sure there's a keydb.cfg file in that path. It can even be empty. However, KeyDB_Tools is a very old tool. I released a more scaled down version called KeyDB_Helper that does basically just FIndVUK functionality. So make sure you're using my KeyDB_Helper application as that has my most recent code.
Your download link in FAQ thread is for KeyDB_Tools_1.0.7.1
That's what I get for doing it late at night. I'll fix it thanks. That tool is old. I should delete it.
LOL :D
Post by SamuriHL »
MartyMcNuts wrote:
Fri Jul 25, 2025 2:16 am
LOL :D
Link was fixed and old tool deleted.
LOL :D
Link is now for KeyDB_Helper_1.0.1.5. Isn't that the old one? It's from the first week of July. didn't you do some updates a few days ago??
Post by SamuriHL »
It should be 1.0.1.6. Is it not?
SamuriHL wrote:
Fri Jul 25, 2025 2:22 am
Yep, it is 1.0.1.6 now. It was 1.0.1.5 a couple of minutes ago as it wanted to overwrite my existing download...
Post by SamuriHL »
MartyMcNuts wrote:
Fri Jul 25, 2025 2:26 am
Sometimes I hate mediafire...
koberulz
Post by koberulz »
Downloaded that one, clicked on Disc Info, it ran some things and is now stuck on “Starting FindVUK validate disc!” All the buttons are greyed out and there's no indication of any sort of progress being made.
Post by SamuriHL »
That's likely stuck on a drive it doesn't know about. Kill it and run it again. It's a bug in my code I've not been able to squash yet.
disneyvader
Post by disneyvader »
what if i get the .tgz file but its roughly 1MB and i cant get Makemkv to open the disc so i can locate the MKB_RO file?
udf: node fe/efe failed!
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/AACS/Content000.cer' at offset '0'
MrPenguin
Post by MrPenguin »
disneyvader wrote:
Fri Jul 25, 2025 9:32 am
This isn't a decryption error, your drive is just struggling to read your disk. The files in a disk's AACS/ directory cannot be encrypted.
keydb_helper
Post by keydb_helper »
Toad King wrote:
Wed Jul 23, 2025 10:43 pm
Dump for The Phoenician Scheme
Hey Toad King, thanks for the disc dump file. The 9282 variant of The Phoenician Scheme has been added to the public keydb.
hulahoo wrote:
Thu Jul 24, 2025 12:35 pm
Dump for Little Buddha
Hey hulahoo, thank you for providing a suitable disc dump file. The F55A variant of Little Buddha has been added to the public keydb.
y2jdmbfan wrote:
Thu Jul 24, 2025 4:55 pm
DR. NO - 4K USA RELEASE
Hey y2jdmbfan, please enable public access to that link
disneyvader wrote:
Thu Jul 24, 2025 4:57 pm
Batman Begins
Hey disneyvader, your Argo and Batman Begins discs have been fully support by the public keydb since September 22 2023. Please follow the link in my first post to configure MakeMKV to utilise the public keydb.
  • LG/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
koberulz
Post by koberulz »
23:30:46 - Drive is NOT in the KnownDrivesList!
23:30:46 - Please post the following information in the Doom9 forum to create a comprehensive list of drives:
23:30:46 - (you'll find this information + additional details also in the file >C:\Users\koberulz\AppData\Local\Temp\Rar$EXa12216.47529\FindVUK\PleasePostInDoom9Forum.txt<
23:30:46 - + VENDOR # PRODUCT-IDENTIF. # REV. # FIRMWARE CR. # INTERFACE # DRIVETYPE # BusEncryptionCapable # BindingNonceGeneration # VENDOR SPECIFIC # FEATURE DESCRIPTOR # COMMENT
23:30:46 - | PIONEER | BD-RW BDR-S12U | 1.03 | | Serial ATAPI | BLURAY/DVD/CD-WRITER | 1 | 1 | 22/10/13 | 01 0D 08 04 1B 01 01 01 |
Post by SamuriHL »
Yes that's what I said was likely the case. My code doesn't handle that case. Remember it's just a UI that sits on top of FindVUK but when FindVUK throws these edge cases I don't handle all of them. Now that FindVUK has thrown that message for that drive, running it again won't encounter the same issue. Or shouldn't. If it does that's a FindVUK problem that's out of my control. When I get a minute I'll add a fix to my code to deal with that scenario. Maybe this weekend.
P.S. For issues with my tool please open a new thread or PM me. This isn't my thread and I don't want to take up space here with tool isues.
y2jdmbfan
Post by y2jdmbfan »
keydb_helper wrote:
Fri Jul 25, 2025 1:15 pm
Batman Begins
DONE
keydb_helper
y2jdmbfan wrote:
Fri Jul 25, 2025 11:04 pm
DONE
Hey y2jdmbfan, your variant of Dr. No was added to the public keydb on June 5.
You can configure MakeMKV to utilise the public keydb by following my instructions here or using SamuriHL's utility for Windows (Link)
