Had issues ripping the newly released blu-rays with AACS v82 encryption using MakeMKV v1.18.1.
I've attached the dump here and also emailed svq@makemkv.com for good measure.
Any help on this would be greatly appreciated.
Thanks a lot!
AACS v82 dump - BRMM-10913
Re: AACS v82 dump - BRMM-10913
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?headroom6657 wrote: Thu May 01, 2025 9:58 am Had issues ripping the newly released blu-rays with AACS v82 encryption using MakeMKV v1.18.1.
The discatt.dat files contained in your dumps do not appear to be valid. They are missing alot of information.headroom6657 wrote: Thu May 01, 2025 9:58 am Had issues ripping the newly released blu-rays with AACS v82 encryption using MakeMKV v1.18.1.
Thanks a lot!
headroom6657
Hi! Apologies for the late reply.MrPenguin wrote: Thu May 01, 2025 1:49 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?headroom6657 wrote: Thu May 01, 2025 9:58 am Had issues ripping the newly released blu-rays with AACS v82 encryption using MakeMKV v1.18.1.
Just tried this and it is now ripping properly. Thanks again for the help!
こんにちは。日本からの投稿です。
このBlu-rayディスク(タイトル:THE VERY BEST OF FANTASY NARITA THOMAS SIMPSON)は、MakeMKVで「このディスクはサポートされていません」と表示されましたので、v82のダンプファイルを添付します。対応よろしくお願いいたします。
Hi, I'm posting from Japan.
This Blu-ray disc (Title: THE VERY BEST OF FANTASY NARITA THOMAS SIMPSON) shows "This disc is not supported" in MakeMKV.
I'm attaching the AACS v82 dump file.
Please add support for this disc. Thank you!
Title: Narita Thomas Simpson
Region: A
Country: Japan
MakeMKV version: 1.18.1
File attached: MKB_v82_NTS_20241225_BD_DD50.tgz
Region: A
Country: Japan
- MKB_v82_NTS_20241225_BD_DD50.tgz
- (101.92 KiB) Downloaded 375 times
Did you email the dump file to svq@makemkv.com?? If not, please do so otherwise MakeMKV will not be able to add support for it!mimimi wrote: Thu Jul 24, 2025 1:52 pm こんにちは。日本からの投稿です。
Region: A
Country: Japan
Hi,headroom6657 wrote: Sun May 04, 2025 6:08 amHi! Apologies for the late reply.MrPenguin wrote: Thu May 01, 2025 1:49 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?headroom6657 wrote: Thu May 01, 2025 9:58 am Had issues ripping the newly released blu-rays with AACS v82 encryption using MakeMKV v1.18.1.
I also tried to download the newest keydb.cfg and copied it into the data folder "C:\Users\<YourUsername>\.MakeMKV". Then I restarted MakeMKV.exe. Same problem again.
Did you extract the KeyDB.cfg from the zip file?geissd wrote: Fri Jul 25, 2025 8:46 pmHi,headroom6657 wrote: Sun May 04, 2025 6:08 amHi! Apologies for the late reply.
さきほどメールでもダンプファイルを送信いたしました。
ご確認をおねがいいたします。
ご確認をおねがいいたします。
Region: A
Country: Japan
