Public KeyDB Disc Submissions
franck2552
Hello, tgz dump file for Hans Zimmer Live in Prague UHD :
https://drive.google.com/file/d/1l6XJfx ... sp=sharing
Thanks.
Thanks.
keydb_helper
Hey franck2552, thank you for providing a suitable disc dump file. Your disc has been added to the public keydb.franck2552 wrote: ↑Sun Jul 20, 2025 9:11 pmHello, tgz dump file for Hans Zimmer Live in Prague UHD :
Thanks.
FootFungus07
keydb_helper
Hey FootFungus07, thanks for providing a suitable disc dump file. The C590 variant of Thunderbolts* has been added to the public keydb.
Dump for The Phoenician Scheme
https://drive.google.com/drive/u/0/fold ... dVbDomRK9I
disneyvader
Can you adjust the "Share" option for this file please, so that people can access it?
disneyvader
Just checking, but have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
I tried to run KeyDB_Tools, but when I start the program it throws an unhandled exception error, saying it "could not find part of the path" and then listing a path to keydb.cfg in my AppData/Roaming directory.
Make sure there's a keydb.cfg file in that path. It can even be empty. However, KeyDB_Tools is a very old tool. I released a more scaled down version called KeyDB_Helper that does basically just FIndVUK functionality. So make sure you're using my KeyDB_Helper application as that has my most recent code.
Your download link in FAQ thread is for KeyDB_Tools_1.0.7.1SamuriHL wrote: ↑Fri Jul 25, 2025 1:24 amMake sure there's a keydb.cfg file in that path. It can even be empty. However, KeyDB_Tools is a very old tool. I released a more scaled down version called KeyDB_Helper that does basically just FIndVUK functionality. So make sure you're using my KeyDB_Helper application as that has my most recent code.
That's what I get for doing it late at night. I'll fix it thanks. That tool is old. I should delete it.MartyMcNuts wrote: ↑Fri Jul 25, 2025 2:04 amYour download link in FAQ thread is for KeyDB_Tools_1.0.7.1SamuriHL wrote: ↑Fri Jul 25, 2025 1:24 amMake sure there's a keydb.cfg file in that path. It can even be empty. However, KeyDB_Tools is a very old tool. I released a more scaled down version called KeyDB_Helper that does basically just FIndVUK functionality. So make sure you're using my KeyDB_Helper application as that has my most recent code.
