(Solved) Dump submitted: MKB20_v77_Point_Break_FAB1
JBG1975
#1 Post by JBG1975 » Wed Jul 23, 2025 3:39 pm
Hi
Much to my surprise this UK UHD release of Point Break from last year is not supported.
This is my first time submitting a dump, I hope this is sufficient. Files also sent to svq@makemkv.com
(Links removed)
Thanks.
MrPenguin
Re: Dunp submitted: MKB20_v77_Point_Break_FAB1
#2 Post by MrPenguin » Wed Jul 23, 2025 5:05 pm
JBG1975 wrote: Wed Jul 23, 2025 3:39 pm Much to my surprise this UK UHD release of Point Break from last year is not supported.
JBG1975
#3 Post by JBG1975 » Wed Jul 23, 2025 6:03 pm
MrPenguin wrote: Wed Jul 23, 2025 5:05 pm
Yes. It was the first thing I did. No luck.
MrPenguin
#4 Post by MrPenguin » Wed Jul 23, 2025 7:40 pm
JBG1975 wrote: Wed Jul 23, 2025 6:03 pm Yes. It was the first thing I did. No luck.
Happily you have also provided your TGZ dump and MKB_RO.inf files, and so it will probably be worth re-checking the KEYDB.cfg file occasionally over the next few days too.
