Dump Submitted - Thunderbolts* 4K UHD
FootFungus07
Post by FootFungus07 »
Marvel's Thunderbolts* TGZ Key File
MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_C590.tgz
Drive File Link:
https://drive.google.com/file/d/1Uk30OK ... drive_link
lemme know if you need help getting the file out, should be open
FootFungus07
Re: Dump Submitted - Thunderbolts* 4K UHD
Just in case this helps.
GFly91
Post by GFly91 »
I just submitted my dump file:
MKB20_v82_MARVEL_STUDIOS'_THUNDERBOLTS_E856
MrPenguin
Post by MrPenguin »
GFly91 wrote: Wed Jul 23, 2025 5:54 pm MKB20_v82_MARVEL_STUDIOS'_THUNDERBOLTS_E856
Could you also upload this file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too.
GFly91
Post by GFly91 »
MrPenguin wrote: Wed Jul 23, 2025 5:58 pm
Thunderbolts
tjparasite
Post by tjparasite »
Thunderbolts,
I believe this is a different dump, my apologies if it is a duplicate:
MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
Emailed Dump file
dawg_ripper
Post by dawg_ripper »
tjparasite wrote: Tue Jul 29, 2025 8:57 pm MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
Thanks, 607C is the one I just got in the mail.
GrantSurewood
Post by GrantSurewood »
Not Sure if this helps: MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
https://drive.google.com/file/d/1QmvSfK ... sp=sharing
MrPenguin
Post by MrPenguin »
GrantSurewood wrote: Tue Jul 29, 2025 9:56 pm Not Sure if this helps: MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
cybergrimes
Post by cybergrimes »
MrPenguin wrote: Tue Jul 29, 2025 11:33 pm Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
This worked for me, thank you
