Dump Submitted - Thunderbolts* 4K UHD
FootFungus07
Post by FootFungus07 »
Marvel's Thunderbolts* TGZ Key File
MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_C590.tgz
Drive File Link:
https://drive.google.com/file/d/1Uk30OK ... drive_link
lemme know if you need help getting the file out, should be open
FootFungus07
Re: Dump Submitted - Thunderbolts* 4K UHD
Just in case this helps.
GFly91
Post by GFly91 »
I just submitted my dump file:
MKB20_v82_MARVEL_STUDIOS'_THUNDERBOLTS_E856
MrPenguin
Post by MrPenguin »
GFly91 wrote:
Wed Jul 23, 2025 5:54 pm
Could you also upload this file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too.
GFly91
Post by GFly91 »
MrPenguin wrote:
Wed Jul 23, 2025 5:58 pm
Thunderbolts
tjparasite
Post by tjparasite »
Thunderbolts,
I believe this is a different dump, my apologies if it is a duplicate:
MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
Emailed Dump file
dawg_ripper
Post by dawg_ripper »
tjparasite wrote:
Tue Jul 29, 2025 8:57 pm
Thanks, 607C is the one I just got in the mail.
GrantSurewood
Post by GrantSurewood »
Not Sure if this helps: MKB20_v77_MARVEL_STUDIOS'_THUNDERBOLTS_607C
https://drive.google.com/file/d/1QmvSfK ... sp=sharing
MrPenguin
Post by MrPenguin »
GrantSurewood wrote:
Tue Jul 29, 2025 9:56 pm
cybergrimes
Post by cybergrimes »
MrPenguin wrote:
Tue Jul 29, 2025 11:33 pm
This worked for me, thank you
