Are Pioneer drives *that* much better at ripping scuffed blurays?
xenphor
Re: Are Pioneer drives *that* much better at ripping scuffed blurays?
Post by xenphor »
Okay, the other drive arrived. Here is the info:
OS device name: /dev/sr1
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: ...
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8E20
Firmware version: 1.01
So far I've tried inserting a UHD and it couldn't read it. Seems like old firmware though?
xenphor wrote: Mon Jul 21, 2025 9:32 pm Okay, the other drive arrived. Here is the info:
Revision: 1.01
Serial number: ...
Windows only
Email me for a flasher see below
Revision: 1.01
Serial number: ...
PM sent.
asmcom
Post by asmcom »
xenphor wrote: Sun Jul 20, 2025 4:02 am
Coopervid wrote: Fri Jul 18, 2025 10:31 am Just post your Makemkv info for both drives when you get them. If you are lucky the XS07 has old firmware.
I received the Vinpower drive. Here is the info:
OS device name: /dev/sr0
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ....
Firmware date: 2022-05-31
Firmware version: ID06
We have stock of Pioneer Drives and acquired more today.
https://shop.uhdfriendlydrives.co.uk/
Regards Asmcom :mrgreen:
xenphor
Post by xenphor »
So far I've noticed that the Pioneer drives have lower average read speeds compared to the Asus drive. The Asus drive can go up to 8x and hovers around 6-7x often, whereas the Pioneer drives are usually around 4-5x or lower. This happens with the Asus drive in an external NexStar enclosure and the 212v connected via Sata.
There have been a couple titles that the Pioneer drives ripped that the Asus could not; however, there are still discs that none of the 4 drives I have can rip. These are all used condition blurays.
Annoyingly, one of the discs I ripped was in obviously poor condition but succeeded, whereas other discs that appeared to be in much better shape failed, so I can't go by appearance.
asmcom
Post by asmcom »
xenphor wrote: Wed Jul 23, 2025 12:17 am So far I've noticed that the Pioneer drives have lower average read speeds compared to the Asus drive. The Asus drive can go up to 8x and hovers around 6-7x often, whereas the Pioneer drives are usually around 4-5x or lower. This happens with the Asus drive in an external NexStar enclosure and the 212v connected via Sata.
The most important function when ripping discs is to thoroughly clean the discs you are backing up. We cannot empatize this enough. Even a scratch or finger mark will stop a disc from backing up properly.
Asmcom
