Public KeyDB Disc Submissions
franck2552
Post by franck2552 »
Hello, tgz dump file for Hans Zimmer Live in Prague UHD :
https://drive.google.com/file/d/1l6XJfx ... sp=sharing
Thanks.
keydb_helper
Post by keydb_helper »
franck2552 wrote:
Sun Jul 20, 2025 9:11 pm
Thanks.
Hey franck2552, thank you for providing a suitable disc dump file. Your disc has been added to the public keydb.
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
FootFungus07
Post by FootFungus07 »
keydb_helper
FootFungus07 wrote:
Tue Jul 22, 2025 6:54 pm
Marvel's Thunderbolts* TGZ File
Hey FootFungus07, thanks for providing a suitable disc dump file. The C590 variant of Thunderbolts* has been added to the public keydb.
Toad King
Post by Toad King »
hulahoo
Post by hulahoo »
y2jdmbfan
Post by y2jdmbfan »
disneyvader
Post by disneyvader »
MrPenguin
Post by MrPenguin »
disneyvader wrote:
Thu Jul 24, 2025 4:57 pm
Batman Begins
Can you adjust the "Share" option for this file please, so that people can access it?
disneyvader
MrPenguin wrote:
Thu Jul 24, 2025 6:19 pm
Batman Begins
just did somehow i forgot to do it...
MrPenguin
Post by MrPenguin »
disneyvader wrote:
Thu Jul 24, 2025 6:27 pm
Just checking, but have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
koberulz
Post by koberulz »
I tried to run KeyDB_Tools, but when I start the program it throws an unhandled exception error, saying it "could not find part of the path" and then listing a path to keydb.cfg in my AppData/Roaming directory.
Post by SamuriHL »
Make sure there's a keydb.cfg file in that path. It can even be empty. However, KeyDB_Tools is a very old tool. I released a more scaled down version called KeyDB_Helper that does basically just FIndVUK functionality. So make sure you're using my KeyDB_Helper application as that has my most recent code.
SamuriHL wrote:
Fri Jul 25, 2025 1:24 am
Your download link in FAQ thread is for KeyDB_Tools_1.0.7.1
Post by SamuriHL »
MartyMcNuts wrote:
Fri Jul 25, 2025 2:04 am
That's what I get for doing it late at night. I'll fix it thanks. That tool is old. I should delete it.
