Dump submitted MKB20_v70_YORHA_VER11A_0579.tgz
ReayMAX
Post by ReayMAX »
I've submitted two .tgz files via email:
MKB20_v70_YORHA_VER11A_0579.tgz(original) and MKB20_v70_舞台少女ヨルハ_Ver_1_1a_0579.tgz(decrypted with Passkey 9, shows as decrypted but remains unplayable).
My drive is an Asus BW-16D1HT flashed with DE_ASUS_BW-16D1HT_3.10_MK. ​​Crucially: when using MakeMKV or Passkey 9, the UHD disc is recognized and allows me to create a full backup (without decryption). Does this confirm that:​​
​​The drive firmware flash succeeded?​​
​​It’s physically capable of reading UHD discs?​​The decryption errors (traceback decrypt errorduring ripping) likely mean I only lack the proper keys — not a drive/hardware issue.
Files are also available here for KEYDB.cfg inclusion:
• Original: https://drive.google.com/file/d/1MaWJYS ... drive_link
• Decrypted (Passkey 9): https://drive.google.com/file/d/1ysVUKe ... drive_link
(Both 116KB, <1MB. Will provide more data if needed.)
MrPenguin
Re: Dump submitted MKB20_v70_YORHA_VER11A_0579.tgz
Post by MrPenguin »
ReayMAX wrote: Sat Jul 19, 2025 6:47 pm (Both 116KB, <1MB. Will provide more data if needed.)
Can you also provide the AACS/MKB_RO.inf file from the physical UHD disk please? The copy of this file inside the TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself. (It's a large file, so just ZIP-compress it and then upload it into Google Drive. Thanks :).)
ReayMAX
Post by ReayMAX »
MrPenguin wrote: Sun Jul 20, 2025 11:07 am
Here's the link, it include .tgz file and MKB_RO.inf file, thanks
https://drive.google.com/file/d/1do_pAE ... drive_link
