keydb_helper wrote: ↑Sat Jul 19, 2025 3:09 amHey MovieMan88, if you'd like to see support for your disc added to the public keydb you will need to provide a link to the dump file.MovieMan88 wrote: ↑Fri Jul 18, 2025 4:32 pmBarry Lyndon UHD Criterion Dump sent via email with the TGZ attached.
Public KeyDB Disc Submissions
Re: Key submission for Final Destination Bloodlines UHD
I sent the .tgz file to the email: svq@makemkv.com as requested to do. Does that email not work anymore, do I need to mount it to a goggle drive instead?
Here is the google drive link for it in case that email doesnt work anymore:
https://drive.google.com/file/d/1MOsKS- ... sp=sharing
MovieMan88 wrote: ↑Sat Jul 19, 2025 5:48 pmI sent the .tgz file to the email: svq@makemkv.com as requested to do. Does that email not work anymore, do I need to mount it to a goggle drive instead?
This particular variant of "Barry Lyndon" has already been added to KEYDB.cfg.
I have 2 .tgz for MKB20_v70_YORHA_VER11A_0579 and i've sent it to svq@makemkv.com last week.
I tried rip it again this week and it still not work, so i hope it can be add to keydb, thanks.
• Original: https://drive.google.com/file/d/1MaWJYS ... drive_link
• Decrypted? (by Passkey 9 maybe): https://drive.google.com/file/d/1ysVUKe ... drive_link
I just tried ripping a fresh Oppenheimer bluray but was running into issues. Tried again with the local KeyDB but still no luck.
Here's a link to a zip with the .tgz archive dump along with the MKB_RO.inf since archive MakeMKV generated was very small:
https://drive.google.com/file/d/1tdWeYD ... drive_link
Trying to get the key added for Final Destination Bloodlines.
Files attached.
Files attached.
No attachment, probably due to size (4.0mb LIMIT on forum).
Hey warcobra & NESpowerhouse, your variant of Oppenheimer has been added to the public keydb. Thank you for including the MKB_RO.inf file.NESpowerhouse wrote: ↑Sat Jul 19, 2025 9:17 pmI just tried ripping a fresh Oppenheimer bluray but was running into issues. Tried again with the local KeyDB but still no luck.
Here's a link to a zip with the .tgz archive dump along with the MKB_RO.inf since archive MakeMKV generated was very small: ...
Hey ReayMAX, as I noted in the first post you'll need to manually zip and include the MKB_RO.inf file from your disc as the dump size is below 3MB. You'll find the required file in the AACS folder on your disc, let me know if you have any questions.ReayMAX wrote: ↑Sat Jul 19, 2025 6:55 pmI have 2 .tgz for MKB20_v70_YORHA_VER11A_0579 and i've sent it to svq@makemkv.com last week.
• Original: ...
• Decrypted? (by Passkey 9 maybe): ...
Hey bigfootindy, thank you for the disc dump file. Your disc has actually been supported by the public keydb since July 9. If configure MakeMKV to use the public keydb file you will be able to decrypt your disc.
Hey swordspirit80, please don't attach files. Use literally any file hosting service and post a link instead.swordspirit80 wrote: ↑Sun Jul 20, 2025 1:44 amTrying to get the key added for Final Destination Bloodlines.
Files attached.
- LG/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Here's the link, the .rar file include MKB20_v70_YORHA_VER11A_0579.tgz and MKB_RO.inf, did you mean like this?keydb_helper wrote: ↑Sun Jul 20, 2025 4:18 amHey warcobra & NESpowerhouse, your variant of Oppenheimer has been added to the public keydb. Thank you for including the MKB_RO.inf file.NESpowerhouse wrote: ↑Sat Jul 19, 2025 9:17 pmI just tried ripping a fresh Oppenheimer bluray but was running into issues. Tried again with the local KeyDB but still no luck.
• Original: ...
Files attached.
https://drive.google.com/file/d/1do_pAE ... drive_link
Kick fucking ass! Ripping this 88GB beast as we speak for my Plex. Thanks!keydb_helper wrote: ↑Sun Jul 20, 2025 4:18 amHey warcobra & NESpowerhouse, your variant of Oppenheimer has been added to the public keydb. Thank you for including the MKB_RO.inf file.
Hello, here is the tgz dump file (v82) for a Japanese concert BD
https://drive.google.com/file/d/1nZn743 ... qnGkr/view
I also sent the tgz file to the email: svq@makemkv.com
Would be very grateful if you could add it to keydb.cfg. Thanks!
