Public KeyDB Disc Submissions
MovieMan88
Re: Key submission for Final Destination Bloodlines UHD
Post by MovieMan88 »
I sent the .tgz file to the email: svq@makemkv.com as requested to do. Does that email not work anymore, do I need to mount it to a goggle drive instead?
keydb_helper wrote:
Sat Jul 19, 2025 3:09 am
MovieMan88 wrote:
Fri Jul 18, 2025 4:32 pm
Barry Lyndon UHD Criterion Dump sent via email with the TGZ attached.
Hey MovieMan88, if you'd like to see support for your disc added to the public keydb you will need to provide a link to the dump file.
MovieMan88
Here is the google drive link for it in case that email doesnt work anymore:
https://drive.google.com/file/d/1MOsKS- ... sp=sharing
MovieMan88 wrote:
Sat Jul 19, 2025 5:48 pm
warcobra
Post by warcobra »
Here is a google drive link for oppenheimer
https://drive.google.com/file/d/1Qfh3e8 ... drive_link
MrPenguin
Post by MrPenguin »
MovieMan88 wrote:
Sat Jul 19, 2025 5:59 pm
MKB20_v82_BARRY_LYNDON_8084.tgz
This particular variant of "Barry Lyndon" has already been added to KEYDB.cfg.
ReayMAX
Post by ReayMAX »
I have 2 .tgz for MKB20_v70_YORHA_VER11A_0579 and i've sent it to svq@makemkv.com last week.
I tried rip it again this week and it still not work, so i hope it can be add to keydb, thanks.
• Original: https://drive.google.com/file/d/1MaWJYS ... drive_link
• Decrypted? (by Passkey 9 maybe): https://drive.google.com/file/d/1ysVUKe ... drive_link
NESpowerhouse
Post by NESpowerhouse »
I just tried ripping a fresh Oppenheimer bluray but was running into issues. Tried again with the local KeyDB but still no luck.
Here's a link to a zip with the .tgz archive dump along with the MKB_RO.inf since archive MakeMKV generated was very small:
https://drive.google.com/file/d/1tdWeYD ... drive_link
bigfootindy
Post by bigfootindy »
swordspirit80
Post by swordspirit80 »
Trying to get the key added for Final Destination Bloodlines.
Files attached.
No attachment, probably due to size (4.0mb LIMIT on forum).
keydb_helper
Post by keydb_helper »
warcobra wrote:
Sat Jul 19, 2025 6:17 pm
NESpowerhouse wrote:
Sat Jul 19, 2025 9:17 pm
Here's a link to a zip with the .tgz archive dump along with the MKB_RO.inf since archive MakeMKV generated was very small: ...
Hey warcobra & NESpowerhouse, your variant of Oppenheimer has been added to the public keydb. Thank you for including the MKB_RO.inf file.
ReayMAX wrote:
Sat Jul 19, 2025 6:55 pm
• Original: ...
• Decrypted? (by Passkey 9 maybe): ...
Hey ReayMAX, as I noted in the first post you'll need to manually zip and include the MKB_RO.inf file from your disc as the dump size is below 3MB. You'll find the required file in the AACS folder on your disc, let me know if you have any questions.
bigfootindy wrote:
Sat Jul 19, 2025 9:34 pm
Fallout Season 1, Disk 2 - 4K UHD
Hey bigfootindy, thank you for the disc dump file. Your disc has actually been supported by the public keydb since July 9. If configure MakeMKV to use the public keydb file you will be able to decrypt your disc.
swordspirit80 wrote:
Sun Jul 20, 2025 1:44 am
Files attached.
Hey swordspirit80, please don't attach files. Use literally any file hosting service and post a link instead.
  • LG/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
ReayMAX
Post by ReayMAX »
keydb_helper wrote:
Sun Jul 20, 2025 4:18 am
• Original: ...
Files attached.
Here's the link, the .rar file include MKB20_v70_YORHA_VER11A_0579.tgz and MKB_RO.inf, did you mean like this?
https://drive.google.com/file/d/1do_pAE ... drive_link
NESpowerhouse
Kick fucking ass! Ripping this 88GB beast as we speak for my Plex. Thanks!
jackycyk0924
Post by jackycyk0924 »
Hello, here is the tgz dump file (v82) for a Japanese concert BD
https://drive.google.com/file/d/1nZn743 ... qnGkr/view
I also sent the tgz file to the email: svq@makemkv.com
Would be very grateful if you could add it to keydb.cfg. Thanks!
keydb_helper
ReayMAX wrote:
Sun Jul 20, 2025 4:33 am
Yep, that is perfect. Your disc has been added to the public keydb. If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Sun Jul 20, 2025 5:27 am
No problem!
jackycyk0924 wrote:
Sun Jul 20, 2025 12:37 pm
Hey jackycyk0924, your disc was added to the public keydb on July 1. Please follow the steps I posted to configure MakeMKV to utilise the keydb and you'll be able to decrypt your disc.
ReayMAX
Post by ReayMAX »
keydb_helper wrote:
Sun Jul 20, 2025 1:56 pm
No problem!
I see it, i will try whether it works next weekend, thanks.
