Dump submitted TAKING_OF_PELHAM_ONE_TWO_THREE_FF7B
erik123
Post by erik123 »
Sent via email
MrPenguin
Re: Dump submitted TAKING_OF_PELHAM_ONE_TWO_THREE_FF7B
Post by MrPenguin »
erik123 wrote: Sat Jul 19, 2025 3:41 pm Sent via email
Could you also upload this file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try to add your disk to the public KEYDB.cfg file too.
erik123
Post by erik123 »
Drive link here: https://drive.google.com/file/d/1PZhugW ... sp=sharing
Edit to add: This is from a Pioneer drive
Post by SamuriHL »
Can you also zip up and add a link for the mkb_ro.inf file for that one? It MIGHT help.
erik123
Post by erik123 »
How to I get that in the size expected? Unzipping the one I'm getting gives one line of text, not the 128 MB that MrPenguin's linked post suggests I should be getting
Post by SamuriHL »
On your disc, in the AACS directory, there's an MKB_RO.inf file. That's the file that needs to be zipped up and a link posted here. NOT the one from the dump file which is quite useless. It's also NOT a text file.
erik123
Post by erik123 »
MKB_RO.inf file copied from the disc and zipped here: https://drive.google.com/file/d/1e5RuBX ... sp=sharing
Post by SamuriHL »
Thanks for uploading that. No promises anything can be done with it but you never know.
EDIT: Yea that didn't help unfortunately. Someone would have to submit a dump from an LG drive.
MrPenguin
Post by MrPenguin »
erik123 wrote: Sun Jul 20, 2025 8:51 pm MKB_RO.inf file copied from the disc and zipped here:
The latest KEYDB.cfg file does at least have a Unit Key for your disk, which means that MakeMKV should at least be able to use Xreveal to decrypt it for you.
erik123
Post by erik123 »
That worked! Thanks!
