Dump Submitted - Barry Lyndon
Toad King
Post by Toad King » Tue Jul 08, 2025 3:08 am
MKB20_v82_BARRY_LYNDON_8C5E
KeyDB works in the meantime.
brannigan
Re: Dump Submitted - Barry Lyndon
Post by brannigan » Wed Jul 09, 2025 12:25 am
Anyone else having issues with KeyDB?
Pete B
Post by Pete B » Mon Jul 14, 2025 7:52 pm
I've just submitted the dump for Criterion's 4K disc too.
We demand satisfaction!
MrPenguin
Post by MrPenguin » Mon Jul 14, 2025 8:02 pm
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?
If this doesn't work, could you also make this TGZ dump file available here please, e.g. by uploading it into (say) OneDrive or Google Drive, and then providing a public download link? This would allow people to try adding your disk to the public KEYDB file.
See Public KEYDB Disc Submissions.
Elephen
Post by Elephen » Thu Jul 17, 2025 11:27 pm
I have been trying to rip this 4K video for more than a week. Has anyone been able to rip it? Thanks.
MrPenguin
Post by MrPenguin » Thu Jul 17, 2025 11:32 pm
Elephen
Post by Elephen » Thu Jul 17, 2025 11:36 pm
Yes. I tried using lower case letters and upper case letters for the file name. When I downloaded the file, it was not zipped, so there was nothing to extract as mentioned in the instruction. My current drive is a Pioneer, which replaced my original LG drive.
MrPenguin
Post by MrPenguin » Thu Jul 17, 2025 11:47 pm
AFAIK the latest KEYDB.cfg file does contain the 8C5E variant of this disk. Do you have a different variant? And if so, perhaps provide your TGZ dump file here please?
Elephen
Post by Elephen » Fri Jul 18, 2025 12:12 am
I hope this helps.
MKB20_v82_BARRY_LYNDON_8084.tgz
MrPenguin
Post by MrPenguin » Fri Jul 18, 2025 12:15 am
Can you upload that file into (say) OneDrive or Google Drive please, and then reply with a public download link? And also email it to svq@makemkv.com, of course.
Elephen
Post by Elephen » Fri Jul 18, 2025 12:21 am
I emailed the link to svq@makemkv.com on day 1. Unfortunately, I have never used OneDrive or Google Drive.
cbuteau
Post by cbuteau » Mon Jul 28, 2025 1:54 am
MrPenguin
Post by MrPenguin » Mon Jul 28, 2025 10:07 am
MKB20_v82_BARRY_LYNDON_8C5E.tgz
cbuteau
Post by cbuteau » Wed Jul 30, 2025 8:38 pm
I tried when I first came here (dah forums)
I will try again.
to clarify I drop in in the same directory that the DUMPS occur.
like for me its a data directory like this.
C:\Users\<username>\.MakeMKV
originally I read in the directory the binaries are installed.
Then I read the directry the dumps get spit.
Still failed?
Should I be uploading multiple dumps?
oe wait a bit and check the thread?
Post by MartyMcNuts » Thu Jul 31, 2025 2:13 am
I will try again.
Still failed?
You extract the KeyDB.cfg file from the zip file to the MakeMKV data directory (where the dumps are).
