Dump Submitted - Road Trip (2000)
Dexterous2969
Post by Dexterous2969 »
MKB20_v77_Road_Trip_8886.tgz emailed.
Re: Dump Submitted - Road Trip (2000)
file name? Each file is unique to the version of the disk, so anyone that has a different version would have no way of knowing if there is a dump being considered for it yet.
MrPenguin
Post by MrPenguin »
Dexterous2969 wrote: Sun Jul 13, 2025 3:57 pm MKB20_v77_Road_Trip_8886.tgz emailed.
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?
If this doesn't work, could you also make this TGZ dump file available here please, e.g. by uploading it into (say) OneDrive or Google Drive, and then providing a public download link? This would allow people to try adding your disk to the public KEYDB file.
See Public KEYDB Disc Submissions.
Dexterous2969
https://limewire.com/d/IGB1K#jWo7FsWGnV
Dump was created using a Pioneer drive - I don't believe our friends at KEYDB can use that.
Latest KEYDB.CFG as of this reply does not contain a matching volume key.
Dexterous2969 wrote: Tue Jul 15, 2025 2:20 pm https://limewire.com/d/IGB1K#jWo7FsWGnV
Read your PM.
Dexterous2969
Appreciated.
keydb_helper
Post by keydb_helper »
Dexterous2969 wrote: Tue Jul 15, 2025 2:20 pm Dump was created using a Pioneer drive - I don't believe our friends at KEYDB can use that.
Hey Dexterous2969, you are correct that Pioneer drives aren't the most helpful from a keydb perspective. The exception is when multiple variants of a disc share a media key. Fortunately for you, a different variant of Road Trip was added to the public keydb on June 18 so it could be used to derive the required keys for your disc.
(There is an additional complicating factor with some Pioneer drives such as the BDR-UD04 found in certain Verbatim products as they produce particularly unhelpful disc dump files.)
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
