Submitted MKB20_v82_『THE_FIRST_SLAM_DUNK』4K_ULTRA_HD_C338.tgz.
Has the decryption for this content been successfully registered?
Dump Submitted: THE_FIRST_SLAM_DUNK
MrPenguin
Re: Dump Submitted: THE_FIRST_SLAM_DUNK
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?watz2z wrote: Sun Jul 13, 2025 2:41 pm Submitted MKB20_v82_『THE_FIRST_SLAM_DUNK』4K_ULTRA_HD_C338.tgz.
If this doesn't work, could you also make this TGZ dump file available here please, e.g. by uploading it into (say) OneDrive or Google Drive, and then providing a public download link? This would allow people to try adding your disk to the public KEYDB file.
See Public KEYDB Disc Submissions.
watz2z
Thank you for your response.
I tried again using the latest keydb.cfg, but I’m still getting the following error message:
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213132721
DEBUG: Code 0 at `{q#WHE]"p5'4|CK:213131341
Here is the link to the shared file: https://drive.google.com/file/d/1uNYWGx ... sp=sharing
I’d appreciate it if you could take a look and let me know if there’s anything else I can try.
Best regards,
Best regards,
