The Amateur 4K
Hipchen63
The Amateur 4K
Post by Hipchen63 » Tue Jul 08, 2025 10:29 pm
This disc is not working
Using LibreDrive mode (v06.3 id=E3767A939283)
Saved AACS dump file as C:\Users\hipch/.MakeMKV/MKB20_v77_The_Amateur_C6AE.tgz
See attached log
MrPenguin
Re: The Amateur 4K
Post by MrPenguin » Wed Jul 09, 2025 2:24 pm
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. C:\Users\hipch\.MakeMKV\ in your case) and restarting MakeMKV?
If this doesn't work, could you make your TGZ dump file available please, e.g. by uploading it into (say) OneDrive or Google Drive, and then replying with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
See Public KEYDB Disc Submissions.
wastekid
Re: The Amateur 4K
Post by wastekid » Thu Jul 10, 2025 2:00 am
Just wanted to chime in: I downloaded the latest keydb.cfg per MrPenguin's instructions just a few minutes before this post, and makemkv can now work with this disc. I believe it's the exact same disc, as Hipchen63's output exactly matched mine when I first tried working with the disc.
I hope this helps Hipchen63 and others.
omk1980
Re: The Amateur 4K
Post by omk1980 » Sun Jul 13, 2025 12:48 pm
this worked for me. never did this before and have always waited for mike to update it. Thanks for the great explanation.
mikesway
Re: The Amateur 4K
Post by mikesway » Sun Jul 20, 2025 7:09 pm
I'm on a Mac and am still having a hard time figuring this out. Can anyone assist me? This is the link for the dump:
https://www.dropbox.com/scl/fo/fx3a4y91 ... 60bnh&dl=0
Re: The Amateur 4K
Post by dcoke22 » Thu Oct 09, 2025 1:43 pm
I emailed MKB20_v77_THE_AMATEUR_C6AE.tgz. It seems no one else has.
