Dump Submitted Fury 4K
ictbydesign
Post by ictbydesign »
As above.
MKB20_v77_FURY_242E.tgz
MrPenguin
Re: Dump Submitted Fury 4K
Post by MrPenguin »
ictbydesign wrote: Thu Jul 10, 2025 2:40 pm MKB20_v77_FURY_242E.tgz
ictbydesign
Yes, i use the program to download it and run it before each rip.
Thanks.
MrPenguin
Post by MrPenguin »
ictbydesign wrote: Fri Jul 11, 2025 7:42 am Yes, i use the program to download it and run it before each rip.
Could you upload your TGZ dump file into (say) OneDrive or Google Drive, and then reply with a download link please? This would allow people to try to add your disk to the public KEYDB.cfg file.
ictbydesign
MrPenguin wrote: Fri Jul 11, 2025 9:53 am
Unfortunately i do not use any cloud storage.
Also i am only using Pioneer drives which from what you told me in the past does not give everything needed.
MrPenguin
Post by MrPenguin »
ictbydesign wrote: Fri Jul 11, 2025 11:11 am Also i am only using Pioneer drives which from what you told me in the past does not give everything needed.
Pioneer drives cannot tell us everything about your disk, but we might still learn something useful about it.
ictbydesign
Disc is now ripping
