Home Alone - No FUTs found
mhunt407
Post by mhunt407 »
Recently tried ripping Home Alone but getting a no FUTs found message. Saw an old thread viewtopic.php?f=8&t=32342&p=148684&hilit=futs#p148684 with the same issue but no resolution.
Have emailed over a tgz, but also attaching it here if anyone can help! Uploaded here: https://drive.google.com/file/d/1SJ-fJF ... share_link
MrPenguin
Re: Home Alone - No FUTs found
Post by MrPenguin »
mhunt407 wrote: Mon Jul 07, 2025 6:12 pm Have emailed over a tgz, but also attaching it here if anyone can help!
mhunt407
Post by mhunt407 »
MrPenguin wrote: Mon Jul 07, 2025 7:23 pm
Yes, I have. No luck unfortunately still same error.
segfaulted
Post by segfaulted »
You may be able to ignore that error and go ahead with the rip. It seems to work fine when I tried it.
