Part of the "Star Trek Original Motion Picture 6 Movie Collection", purchased from Uncle Bezos' General Store.
Surprised there wasn't already a key, must be a recent reprint. Key is also not in the FindVUK database.
MKB20_v76_Star_Trek_III-_The_Search_for_Spock_7713
Dump submitted for Star Trek III: The Search for Spock
babypuncher
MrPenguin
Re: Dump submitted for Star Trek III: The Search for Spock
Could you make this TGZ dump file available please, e.g. by uploading into (say) OneDrive or Google Drive, and then providing a download link? This would allow people to try to add your disk to the public KEYDB database.
And could you also provide this disk's actual AACS/MKB_RO.inf file please, because the copy of this file inside the TGZ dump has almost certainly been truncated to only 56 bytes, making it unusable to anyone except MakeMKV itself.
babypuncher
Sure thing, here you go: https://drive.google.com/file/d/1aDPbbH ... sp=sharingMrPenguin wrote: Sun Jul 06, 2025 8:33 pmCould you make this TGZ dump file available please, e.g. by uploading into (say) OneDrive or Google Drive, and then providing a download link? This would allow people to try to add your disk to the public KEYDB database.
I'll keep this in mind next time I find another disc missing from the database.
MrPenguin
Thanks, but I think this disk is already in the public KEYDB.cfg file:
0xC417FF2ED8D242CE75DA0AAED46EF765641B5801 = STAR_TREK_III_TSFS_UHD (Star Trek III: The Search for Spock) | D | 2021-06-15 | ...-
babypuncher
Yep, not the first time I've used the FindVUK database with MakeMKV. I pulled a fresh copy of it this morning. This looks right to me: https://postimg.cc/qz6JDpQwMrPenguin wrote: Sun Jul 06, 2025 10:34 pm Thanks, but I think this disk is already in the public KEYDB.cfg file:Did you copy the KEYDB.cfg file into the correct directory? It should be put into the same directory where MakeMKV also writes its TGZ dump files.Code: Select all
EDIT
Well, it seems maybe MakeMKV has gotten pickier about how the file is named? Just lower-casing the extension caused it to pick it up.
nd4spd81
I cannot get this disc to even open. the other three in the pack have opened and ripped. the drive is a pioneer bdr-s13u using bdr-213t firmware that I purchased through this site. is there any tricks to get the disc to open? I get scsi errors until I get an internal error operation was canceled. it has been working great on so many other movies and I have been able to rip some after this disc issue popped up too.
MrPenguin
Did MakeMKV generate a TGZ dump file for this disk? Because if so, you should email it to svq@makemkv.com. And also upload it into (say) OneDrive or Google Drive please, and then reply with a public download link, as this would allow people to try adding your disk to the public KEYDB.cfg file as well.nd4spd81 wrote: Mon Feb 09, 2026 5:43 pm I cannot get this disc to even open. the other three in the pack have opened and ripped.
