Fallout UHD Season 1
Cultural-Climate9187
Post by Cultural-Climate9187 » Sat Jul 05, 2025 6:02 pm
Obviously being brand new, the encryption for watching from disc using VLC and Ripping is currently unavailible, dropping the TGZ since i have seen it done on previous posts unsure if that information helps on breaking the encrytpion key but figured i would drop on the off chance anyone is having a similar issue there is a post about it, if someone can do something with the files added even better.
Hell wish there was a instructional video on a potential brute force method.
MrPenguin
Re: Fallout UHD Season 1
Post by MrPenguin » Sat Jul 05, 2025 6:11 pm
Cultural-Climate9187 wrote: Sat Jul 05, 2025 6:02 pm Hell wish there was a instructional video on a potential brute force method.
Have you seen the Public KEYDB Disc Submission thread?
Post by Cultural-Climate9187 » Sat Jul 05, 2025 6:40 pm
MrPenguin wrote: Sat Jul 05, 2025 6:11 pm
Nope but looking NOW jeez seems like a resource thanks for pointing me that way :D Though upon further inspection pioneer drive, mine being external seems i can't help provide? though its a glance read will put my all into it after my food has finished cooking!
Post by Cultural-Climate9187 » Sat Jul 05, 2025 6:43 pm
I do use the KeyDB Helper mind you which i think uses find vuk and mostly sets it up completely.
Post by SamuriHL » Sat Jul 05, 2025 6:46 pm
Yes, under the covers I set up FindVUK and use that to manage the KeyDB (syncing, uploading keys, etc). When you perform a synchronize it uses FindVUK to pull down the latest keydb.cfg and then my code copies it to the MakeMKV data directory.
But for titles that aren't in the KeyDB, posting a link to the tgz (with a non-pioneer drive from what I understand) allows others to add keys. The thing with the Pioneer drives is not all of them allow the VID to be read so it doesn't provide all the information needed for creating the VUK.
Post by Cultural-Climate9187 » Sat Jul 05, 2025 6:48 pm
SamuriHL wrote: Sat Jul 05, 2025 6:46 pm Yes, under the covers I set up FindVUK and use that to manage the KeyDB (syncing, uploading keys, etc). When you perform a synchronize it uses FindVUK to pull down the latest keydb.cfg and then my code copies it to the MakeMKV data directory.
Honestly used it since you recommended in my last thread :D, Not sure if it needs updating or not last time it was a mediafire link do you update the same link or have a git to get most updated version with relative ease? currently on 1.82
Post by SamuriHL » Sat Jul 05, 2025 6:49 pm
Cultural-Climate9187 wrote: Sat Jul 05, 2025 6:48 pm Honestly used it since you recommended in my last thread :D, Not sure if it needs updating or not last time it was a mediafire link do you update the same link or have a git to get most updated version with relative ease? currently on 1.82
I just updated it today. It probably won't make any difference for your use case but it's always good to keep it up to date. Find 1.0.1.5 here:
viewtopic.php?f=12&t=16883&p=166510#p166510
lfoust
Post by lfoust » Sat Jul 19, 2025 5:51 pm
I was able to rip all 3 discs. Disc 2 did require me to manually update my keydb.cfg for it to work. Here is how it layed out for me: https://thediscdb.com/series/fallout-20 ... son-one-4k
Post by SamuriHL » Sat Jul 19, 2025 5:59 pm
Ah hell yea thanks for that. I've been putting off ripping MKV's from my protected ISOs. That will make it easier!
