Dump Submitted - Blood Simple 4K UHD
Millertime
Post by Millertime »
MKB20_v77_BLOOD_SIMPLE_D6D4
tomrammer
Re: Dump Submitted - Blood Simple 4K UHD
Post by tomrammer »
4k Criterion Dump sumbitted:
MKB20_v77_BLOOD_SIMPLE_6381.tgz
MrPenguin
Post by MrPenguin »
tomrammer wrote: Tue Jul 01, 2025 10:39 pm 4k Criterion Dump sumbitted:
If this doesn't work, then could you also upload this TGZ dump file into (say) OneDrive or Google Drive, and then provide a download link please? This would help people add your disk to the public KEYDB.cfg file too.
tomrammer
Post by tomrammer »
I've tried updating my KEYDB.cfg file, but to no avail.
This link should work (fingers crossed)
https://drive.google.com/file/d/11uof2X ... drive_link
MrPenguin
Post by MrPenguin »
tomrammer wrote: Sat Jul 05, 2025 2:13 pm This link should work (fingers crossed)
Thanks, and can you also adjust the file's "Share" option please, so that people can access it?
BTW I suspect the AACS/MKB_RO.inf file inside your TGZ dump file will have been truncated to only 56 bytes, which would make it unusable to anyone except MakeMKV itself. (Having a truncated MKB_RO.inf file inside would make your TGZ dump file only a few 100 KB in size, instead of about 3+ MB.) In which case, could you also provide the MKB_RO.inf file from your physical UHD disk please? I would recommend zip-compressing it before uploading it.
tomrammer
Post by tomrammer »
Curious. Wonder why/how that file got truncated. In any event, I've zipped together a new dump file along with te MKB_RO.inf file in the attached link. According to Google Drive, anyone with the link should be able to access it.
https://drive.google.com/file/d/1eSxxlY ... sp=sharing
tomrammer
Post by tomrammer »
Thank You!!
