Dump Submitted - Blood Simple 4K UHD
Millertime
MKB20_v77_BLOOD_SIMPLE_D6D4
tomrammer
Re: Dump Submitted - Blood Simple 4K UHD
4k Criterion Dump sumbitted:
MKB20_v77_BLOOD_SIMPLE_6381.tgz
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?tomrammer wrote: Tue Jul 01, 2025 10:39 pm 4k Criterion Dump sumbitted:
If this doesn't work, then could you also upload this TGZ dump file into (say) OneDrive or Google Drive, and then provide a download link please? This would help people add your disk to the public KEYDB.cfg file too.
tomrammer
I've tried updating my KEYDB.cfg file, but to no avail.
This link should work (fingers crossed)
https://drive.google.com/file/d/11uof2X ... drive_link
MrPenguin
Thanks, and can you also adjust the file's "Share" option please, so that people can access it?
BTW I suspect the AACS/MKB_RO.inf file inside your TGZ dump file will have been truncated to only 56 bytes, which would make it unusable to anyone except MakeMKV itself. (Having a truncated MKB_RO.inf file inside would make your TGZ dump file only a few 100 KB in size, instead of about 3+ MB.) In which case, could you also provide the MKB_RO.inf file from your physical UHD disk please? I would recommend zip-compressing it before uploading it.
tomrammer
Curious. Wonder why/how that file got truncated. In any event, I've zipped together a new dump file along with te MKB_RO.inf file in the attached link. According to Google Drive, anyone with the link should be able to access it.
https://drive.google.com/file/d/1eSxxlY ... sp=sharing
tomrammer
Thank You!!
