Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
Hi everyone, I've created this thread to act as a central location for posting disc dump file submissions for the public keydb. Thank you to the moderation team for allowing this thread to be trialed.
  • Do not post to this thread if your answer to any of the submission template questions is 'No'.
  • Do not just extract and upload the 56 byte MKB_RO.inf file from a partial disc dump file. This is not helpful.
  • Do not post a strict subset of the template to this thread. All sections are required and nothing should be omitted or skipped.
  • Do not post links which are broken, unavailable or not publicly accessible. Before posting a link in this thread, open up incognito mode and verify that your disc dump file and MKB_RO.inf file can actually be downloaded by the public.
  • Do not post disc dump files generated via virtual drives. Disc dump files must be generated via physical disc drive.
Submission template:
[b]Disc type:[/b]
[b]Disc ID:[/b]
[b]Disc dump filename:[/b]
[b]Drive:[/b]
[b]Drive firmware:[/b]
[b]LibreDrive status:[/b]
[b]Did you sync the public keydb within the last 15 minutes?[/b]
[b]Have you verified that all submission links are accessible in incognito/private browsing?[/b]
[b]Is your MKB_RO.inf file size at least 2MB?[/b]
[b]MKB_RO.inf link:[/b] (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the AACS folder on the original disc)
[b]Disc dump link:[/b]
Submission example:
Disc type: UHD
Disc ID: 0x3107C2E7A9E653308559C7ED8E261D9702F4C5F4
Disc dump filename: MKB20_v77_The_Sound_of_Music_BCE8
Drive: BW-16D1HT
Drive firmware: 3.10MK
LibreDrive status: Enabled
Is your MKB_RO.inf file size at least 2MB? Yes
MKB_RO.inf link: <Link>
Disc dump link: <Link>
I hope this will lead to less issues caused by large file attachments and reduce confusion regarding the state of native title support in MakeMKV.
What is the public keydb?
The public keydb (key database) is a community run initiative which provides a database of keys for decrypting Blu-ray discs. The public keydb is independent of MakeMKV but if configured properly MakeMKV can utilise the public keydb to decrypt discs which it does not yet natively support.
Emailing disc dump files to the MakeMKV team is still recommended to assist with native title support.
What is the benefit of providing disc dump files?
If you can provide a suitable disc dump file in this thread, it will be supported by the public keydb within 48 hours. Otherwise you may need to wait days or even weeks for MakeMKV to natively support your disc.
Link to instructions for configuring MakeMKV to utilise the public keydb
Link to the public keydb homepage
Link to SamuriHL's KeyDBTool for Windows
Submission Guidelines
  • Please include the disc ID in your submission template. The disc ID is the SHA-1 hash of the Unit_Key_RO.inf file in your discs AACS folder.
  • UHD disc dump files are generally 3-8MB and named something like MKB20_v82_EXAMPLE_UHD_048C.tgz.
  • You will also need to provide the MKB_RO.inf file as an additional link alongside your disc dump file link.
  • Copy the original, multi-megabyte MKB_RO.inf file from the AACS folder on your disc and provide a link to this MKB_RO.inf file.
  • If your MKB_RO.inf file is not several megabytes in size, it is probably not useful for UHD discs.
Don't forget to try out the latest public keydb before posting to this thread. Remember, even if MakeMKV doesn't natively support your disc it may already be supported by the public keydb
Last edited by keydb_helper on Thu Oct 22, 2026 2:31 pm, edited 16 times in total.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
Post by SamuriHL »
This is great! Bumping it up so it stays visible for people. Maybe it should be stickied.
SamuriHL wrote: Thu Jun 26, 2025 2:26 pm This is great! Bumping it up so it stays visible for people. Maybe it should be stickied.
I will ask Woodstock if he can do that.
keydb_helper
Coopervid wrote: Thu Jun 26, 2025 8:47 pm
Thanks SamuriHL, Coopervid, and Woodstock for suggesting, arranging, and approving the stickying of this thread
KeyDB Priority List
garnuts
Sinners MKB20_v82_Sinners_5992.tgz (Steelbook USA)
Post by garnuts »
Here's the dump for the new Sinners Steelbook from the US
https://drive.google.com/file/d/11kVPTU ... sp=sharing
AACS/Unit_Key_RO.inf last date modified 6/4/25
keydb_helper
Re: Sinners MKB20_v82_Sinners_5992.tgz (Steelbook USA)
garnuts wrote: Thu Jul 03, 2025 8:53 pm Hi,
Thanks garnuts, the 5992 variant of Sinners has been added to the public keydb.
KeyDB Priority List
reversion
Post by reversion »
I’m submitting a key dump for a standard (non-UHD) Blu-ray and wasn’t sure if non-UHD titles are accepted here. Any advice would be appreciated.
MKB_v82_USG_20THBESTTOUR_LIVEBD_FCDA.tgz + MKB_RO.inf
https://drive.google.com/file/d/1eyUbPL ... sp=sharing
keydb_helper
reversion wrote: Fri Jul 04, 2025 7:09 am Hi,
Thanks for the disc dump, it has been added to the public keydb.
I have no problem with standard AACS 1.0 titles being posted in this thread. But it is important to remember that you can currently generate the disc keys for AACS 1.0 titles by yourself. See SamuriHl's post here
KeyDB Priority List
youley
Post by youley »
keydb_helper
youley wrote: Fri Jul 04, 2025 4:06 pm UK Superman 2 The Donner Cut UHD
Thanks for the disc dump file youley. The 3FF8 variant of Superman 2: The Donner Cut has been added to the public keydb.
KeyDB Priority List
carlosli
Post by carlosli »
Here is my dump, hope you can help to decrypt
https://drive.google.com/file/d/1uLbbkq ... sp=sharing
MrPenguin
Post by MrPenguin »
carlosli wrote: Fri Jul 04, 2025 8:54 pm Here is my dump, hope you can help to decrypt
Where is this dump file?
Files over 4MB won't go through... and a lot of the recent upload attempts were for very large files.
carlosli
Post by carlosli »
MrPenguin wrote: Fri Jul 04, 2025 10:47 pm
mich52
Post by mich52 »
