MrPenguin
Posts: 1955 Joined: Thu Oct 19, 2023 11:31 pm
Post
by MrPenguin » Thu Jul 03, 2025 4:14 pm
jenrashe wrote: Thu Jul 03, 2025 4:11 pm
Decrypted Unit Key: BB3B8DCDCA4E776E8909951EA791D0DD [FOUND]
ERROR: Unit Key(s) tested with 3 aligned units : [INVALID]
If the disc isn't AACS-encryted in the first place then trying to decrypt it with the Unit Key will produce nonsense.
Starting FindVUK validate disc!
18:10:26 - ERROR! Couldn't create BlurayMetaXML!
Failed even to create the BlurayMetaXML file???
Posts: 2781 Joined: Mon Jun 14, 2010 5:32 pm
Post
by SamuriHL » Thu Jul 03, 2025 4:26 pm
Something looks highly off there. No idea what but definitely doesn't look normal. I don't remember if I check the aligned units before testing the decryption key to see if it's already decrypted. It never really occurred to me to do so tbh.
MrPenguin
Post
by MrPenguin » Thu Jul 03, 2025 4:36 pm
SamuriHL wrote: Thu Jul 03, 2025 4:26 pm
To be fair, this would only be the
second unencrypted Bluray I've ever heard of, the other being "The Wicker Man".
Post
by SamuriHL » Thu Jul 03, 2025 4:44 pm
Yea. Once I get into the code for some other things I'll consider adding something to check while I'm at it. Won't that be fun. lol
jenrashe
Posts: 35 Joined: Wed Jul 02, 2025 1:44 pm
Post
by jenrashe » Fri Jul 04, 2025 6:24 am
hello i tried again this morning :
Validating disc...
08:20:52 - ----------- FindVUK 1.82 -----------
To close FindVUK simply press the ESC key
08:20:52 - MODE: ValidateDisc
08:20:52 - DriveLetter : D
08:20:52 - SettingsFile: >C:\Users\\Desktop\FindVUK\config\FindVUK.ini<
08:20:52 - Logfile >C:\Users\Desktop\FindVUK\log\2025-07-04_FindVUK.txt< Default Loglevel >2<
08:20:52 - Update enabled - check for update
08:20:52 - No update required
08:20:52 - Open Main-KEYDB file: >C:\Users\\AppData\Roaming\aacs\KEYDB.cfg<
08:20:58 - Open Backup-KEYDB file: >C:\Users\\Desktop\FindVUK\VUKbackup\KEYDB.cfg<
08:20:58 - Get basic AACS data
08:20:58 - AACS folder on disc is reachable - Validate is possible
08:21:00 - VolumeName >2046<
08:21:00 - DiscId >64D2198531B536D03C16DDACADCB27B03DAF998E< (2025-04-17)
08:21:00 - DiscType >UHD<
08:21:00 - MKB Revision >82<
08:21:00 - Disc-BusEncEnabled >1<
08:21:00 - Drve-BusEncCapable >1<
08:21:00 - ==> Bus Encryption active!
08:21:00 - UnitKeyCount >1<
08:21:00 - >>> UnitKeyENC (1) >E0C5A8B1EE39C9A224907A531786E7B5<
08:21:00 - Data read from KeyDB.cfg:
08:21:00 - VolumeId: F7C74DE3FE90D5F9D12CE78C95ADB5AA
08:21:00 - MediaKey: 2FEF9E6C94835078963737C8430EB7B4
08:21:00 - VUK: C0E1BE3DBAA7E6860BA53044654BBB1F
08:21:00 - UnitKeys (1):
08:21:00 - >>> UnitKeyDEC (1) >BB3B8DCDCA4E776E8909951EA791D0DD<
08:21:00 - UnitKeys recalculated with VUK:
08:21:00 - BusEncryption enabled => either ReadDataKey or disabling of BusEncryption required
08:21:00 - External tool to disable bus encryption defined >"C:\Program Files (x86)\MakeMKV\makemkvcon64.exe" info dev:$DRIVE$ <
08:21:03 - External tool successfully disabled BusEncryption!
08:21:03 - --- PART 2 --- VALIDATE VUK/UNITKEYS ---
08:21:04 - Drive is detected as 'REAL BLURAY' drive
08:21:04 - M2TS files found >13<
08:21:09 - Validation successful! UnitKeys are valid!!
08:21:09 - MediaKey and VolumeID match VUK!
08:21:09 - -------------------------------------------------------
08:21:09 - MetaTitle : 2046
08:21:09 - VolumeName : 2046
08:21:09 - DiscID : 64D2198531B536D03C16DDACADCB27B03DAF998E
08:21:09 - DateDiscID : 2025-04-17
08:21:09 - DiscType : UHD
08:21:09 - VUK : C0E1BE3DBAA7E6860BA53044654BBB1F
08:21:09 - MEDIAKEY : 2FEF9E6C94835078963737C8430EB7B4
08:21:09 - VOLUMEID : F7C74DE3FE90D5F9D12CE78C95ADB5AA
08:21:09 - >>> UnitKeyDEC (1) >BB3B8DCDCA4E776E8909951EA791D0DD< (Unused)
08:21:09 - MKBrev : 82
08:21:09 - BusEncrEn : 1
08:21:09 - AACS : 1
08:21:09 - BD+ : 0
08:21:09 - --- Write entry in main-keydb file ---
08:21:09 - Keys in Keyfile: 166746 keys - KeyFile: C:\Users\\AppData\Roaming\aacs\KEYDB.cfg
08:21:09 - Disc with ID >64D2198531B536D03C16DDACADCB27B03DAF998E< is already in file - need to compare the details
08:21:09 - KEYDB: Identical entry already present in keydb-file
08:21:09 - >> Identical: TITLE, VUK, DATE, MEDIAKEY, VOLUMEID, UNITKEYS, COMMENT - Different: nothing >> will NOT write new entry in keydb-file
08:21:09 - Identical entry already present in keydb-file - file is not changed
08:21:10 - --- Write entry in backup-keydb file ---
08:21:10 - Keys in Keyfile: 3 keys - KeyFile: C:\Users\Desktop\FindVUK\VUKbackup\KEYDB.cfg
08:21:10 - Disc with ID >64D2198531B536D03C16DDACADCB27B03DAF998E< is already in file - need to compare the details
08:21:10 - KEYDB: Identical entry already present in keydb-file
08:21:10 - >> Identical: TITLE, VUK, DATE, MEDIAKEY, VOLUMEID, UNITKEYS, COMMENT - Different: nothing >> will NOT write new entry in keydb-file
08:21:10 - Identical entry already present in keydb-file - file is not changed
08:21:10 - ERROR! Couldn't create BlurayMetaXML!
08:21:10 - ERROR! Couldn't upload entry to OnlineDB
08:21:10 - ERROR! Validate_UploadResultToOnlineDatabase failed!
08:21:10 - ERROR! ShowResult for mode ValidateDisc failed!
i have always the same error :
MakeMKV v1.18.1 win(x64-release) démarré
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Sauvegarde du disque dans le dossier "C:/Users/Desktop/s21/bluray 4k/2046"
Fichier de vidange AACS enregistré sous C:\Users\/.MakeMKV/MKB20_v82_2046_8F66.tgz
La clé de volume est inconnue pour ce dique - la vidéo ne peut être décryptée
Sauvegarde échouée
jenrashe
Post
by jenrashe » Fri Jul 04, 2025 6:48 pm
i retry again unfortunately
jenrashe
Post
by jenrashe » Sun Jul 06, 2025 9:36 am
i tried this morning and the same result
Validating disc...
11:33:21 - ----------- FindVUK 1.82 -----------
11:33:21 - MODE: ValidateDisc
11:33:21 - DriveLetter : D
11:33:21 - SettingsFile: >C:\Users\\Desktop\FindVUK\config\FindVUK.ini<
11:33:21 - Logfile >C:\Users\godai\Desktop\FindVUK\log\2025-07-06_FindVUK.txt< Default Loglevel >2<
11:33:21 - Update enabled - check for update
11:33:21 - No update required
11:33:21 - Open Main-KEYDB file: >C:\Users\\AppData\Roaming\aacs\KEYDB.cfg<
11:33:26 - Open Backup-KEYDB file: >C:\Users\\Desktop\FindVUK\VUKbackup\KEYDB.cfg<
11:33:26 - Get basic AACS data
11:33:26 - AACS folder on disc is reachable - Validate is possible
11:33:27 - VolumeName >2046<
11:33:27 - DiscId >64D2198531B536D03C16DDACADCB27B03DAF998E< (2025-04-17)
11:33:27 - DiscType >UHD<
11:33:27 - MKB Revision >82<
11:33:27 - Disc-BusEncEnabled >1<
11:33:27 - Drve-BusEncCapable >1<
11:33:27 - ==> Bus Encryption active!
11:33:27 - UnitKeyCount >1<
11:33:27 - >>> UnitKeyENC (1) >E0C5A8B1EE39C9A224907A531786E7B5<
11:33:27 - Data read from KeyDB.cfg:
11:33:27 - VolumeId: F7C74DE3FE90D5F9D12CE78C95ADB5AA
11:33:27 - MediaKey: 2FEF9E6C94835078963737C8430EB7B4
11:33:27 - VUK: C0E1BE3DBAA7E6860BA53044654BBB1F
11:33:27 - UnitKeys (1):
11:33:27 - >>> UnitKeyDEC (1) >BB3B8DCDCA4E776E8909951EA791D0DD<
11:33:27 - UnitKeys recalculated with VUK:
11:33:27 - BusEncryption enabled => either ReadDataKey or disabling of BusEncryption required
11:33:27 - External tool to disable bus encryption defined >"C:\Program Files (x86)\MakeMKV\makemkvcon64.exe" info dev:$DRIVE$ <
11:33:30 - External tool successfully disabled BusEncryption!
11:33:30 - --- PART 2 --- VALIDATE VUK/UNITKEYS ---
11:33:30 - Drive is detected as 'REAL BLURAY' drive
11:33:30 - M2TS files found >13<
11:33:30 - Validation successful! UnitKeys are valid!!
11:33:30 - MediaKey and VolumeID match VUK!
11:33:30 - -------------------------------------------------------
11:33:30 - MetaTitle : 2046
11:33:30 - VolumeName : 2046
11:33:30 - DiscID : 64D2198531B536D03C16DDACADCB27B03DAF998E
11:33:31 - DateDiscID : 2025-04-17
11:33:31 - DiscType : UHD
11:33:31 - VUK : C0E1BE3DBAA7E6860BA53044654BBB1F
11:33:31 - MEDIAKEY : 2FEF9E6C94835078963737C8430EB7B4
11:33:31 - VOLUMEID : F7C74DE3FE90D5F9D12CE78C95ADB5AA
11:33:31 - >>> UnitKeyDEC (1) >BB3B8DCDCA4E776E8909951EA791D0DD< (Unused)
11:33:31 - MKBrev : 82
11:33:31 - BusEncrEn : 1
11:33:31 - AACS : 1
11:33:31 - BD+ : 0
11:33:31 - -------------------------------------------------------
11:33:31 - --- Write entry in main-keydb file ---
11:33:31 - Keys in Keyfile: 166816 keys - KeyFile: C:\Users\godai\AppData\Roaming\aacs\KEYDB.cfg
11:33:31 - Disc with ID >64D2198531B536D03C16DDACADCB27B03DAF998E< is already in file - need to compare the details
11:33:31 - KEYDB: Identical entry already present in keydb-file
11:33:31 - >> Identical: TITLE, VUK, DATE, MEDIAKEY, VOLUMEID, UNITKEYS, COMMENT - Different: nothing >> will NOT write new entry in keydb-file
11:33:31 - Identical entry already present in keydb-file - file is not changed
11:33:31 - --- Write entry in backup-keydb file ---
11:33:31 - Keys in Keyfile: 8 keys - KeyFile: C:\Users\Desktop\FindVUK\VUKbackup\KEYDB.cfg
11:33:32 - Disc with ID >64D2198531B536D03C16DDACADCB27B03DAF998E< is already in file - need to compare the details
11:33:32 - KEYDB: Identical entry already present in keydb-file
11:33:32 - >> Identical: TITLE, VUK, DATE, MEDIAKEY, VOLUMEID, UNITKEYS, COMMENT - Different: nothing >> will NOT write new entry in keydb-file
11:33:32 - Identical entry already present in keydb-file - file is not changed
11:33:32 - ERROR! Couldn't create BlurayMetaXML!
11:33:32 - ERROR! Couldn't upload entry to OnlineDB
11:33:32 - ERROR! Validate_UploadResultToOnlineDatabase failed!
11:33:32 - ERROR! ShowResult for mode ValidateDisc failed!
if a buy a new UHD DISC , will ite be the same result as impossible to make a backup ?
MrPenguin
Post
by MrPenguin » Sun Jul 06, 2025 11:32 am
jenrashe wrote: Sun Jul 06, 2025 9:36 am
Try creating an
encrypted backup.
jenrashe
Post
by jenrashe » Sun Jul 06, 2025 11:51 am
how can i do that ?
MrPenguin
Post
by MrPenguin » Sun Jul 06, 2025 12:03 pm
jenrashe wrote: Sun Jul 06, 2025 11:51 am
how can i do that ?
Open MakeMKV and immediately press the "Backup" button (2nd button on the button bar). Uncheck its "decrypt" option, and then select which directory to back your disk up into.
Once you have created your encrypted backup, remove or rename its
AACS/ directory, and then try opening the back up in MakeMKV.
jenrashe
Post
by jenrashe » Sun Jul 06, 2025 2:59 pm
That will resovle my problem's key ?
i am doing the thing...1hour waiting but i can previsualize the folders who'll be created
3 folder are present:
AACS
BDMV
CERTIFICATE
So i delete the folder AACS after ?
jenrashe on Sun Jul 06, 2025 3:16 pm, edited 1 time in total.
Post
by SamuriHL » Sun Jul 06, 2025 3:15 pm
Delete it or rename it.
jenrashe
Post
by jenrashe » Sun Jul 06, 2025 4:34 pm
so i delete the folder aacs and so now it s ok.
I can read it easely and make an image disc reading in my oppo without the aacs files
thanks a lot men
MrPenguin
Post
by MrPenguin » Sun Jul 06, 2025 4:36 pm
jenrashe wrote: Sun Jul 06, 2025 4:34 pm
This proves that your disk was not actually encrypted with its Unit Key. Rare, but not unheard of...
jenrashe
Post
by jenrashe » Sun Jul 06, 2025 4:38 pm
ok i will know the tips for the future
