Dumb submitted - 2046
jenrashe
Post by jenrashe » Wed Jul 02, 2025 2:13 pm
keydb_helper
Re: Dumb submitted - 2046
Post by keydb_helper » Wed Jul 02, 2025 10:23 pm
emailed MKB20_v82_2046_8F66.tgz
Thanks for providing a suitable disc dump file. The 8F66 variant of 2046 has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
jenrashe
Post by jenrashe » Thu Jul 03, 2025 6:22 am
hello i have just try with the versions keydb_fra and keydb_eng
and no one can decrypt the disc
Fichier de vidange AACS enregistré sous C:\Users\user/.MakeMKV/MKB20_v82_2046_8F66.tgz
La clé de volume est inconnue pour ce dique - la vidéo ne peut être décryptée
Sauvegarde échouée
Getting disc info...
Validation Data: EB428C4D8DD3A0436A40C5285957290C [FOUND]
Media Key: 2FEF9E6C94835078963737C8430EB7B4 [VALID]
VUK: C0E1BE3DBAA7E6860BA53044654BBB1F [VALID]
Encrypted Unit Key: E0C5A8B1EE39C9A224907A531786E7B5 [FOUND]
Decrypted Unit Key: BB3B8DCDCA4E776E8909951EA791D0DD [FOUND]
ERROR: Unit Key(s) tested with 3 aligned units : [INVALID]
[(Disc Info)]
[DiscID]: 0x64D2198531B536D03C16DDACADCB27B03DAF998E
[Volume]: 2046
[Title]: 2046
[Date]: 2025-04-17
[MediaKey]: 0x2FEF9E6C94835078963737C8430EB7B4
[VID]: 0xF7C74DE3FE90D5F9D12CE78C95ADB5AA
[VUK]: 0xC0E1BE3DBAA7E6860BA53044654BBB1F
[MKB]: 82
[UnitKey]: 1-0xBB3B8DCDCA4E776E8909951EA791D0DD
[KEYDB_STATUS]: (VALIDATED)
[STATUS]: complete
[DiscType]: UHD
[(KeyDB Entry Info)]
[Volume]: 2046
[Title]: 2046
[Date]: 2025-04-17
[MKB]: 82
[MakeMKV SUPPORTED]: TRUE
keydb_helper
Post by keydb_helper » Thu Jul 03, 2025 8:25 am
Sauvegarde échouée
Thanks for letting me know. Your original disc dump had an incomplete verification data file. Could you please delete your original MKB20_v82_2046_8F66.tgz file, reboot your computer, and have MakeMKV generate a new disc dump file for your 2046 disc? Post the link to the alternative disc dump file when you get a chance.
The media key (MK) is definitely correct but the volume ID may be invalid and that would lead to an invalid unit key which prevents playback/decryption.
jenrashe
Post by jenrashe » Thu Jul 03, 2025 10:27 am
here the new tgz withe same error
https://drive.google.com/file/d/1UB8JQd ... drive_link
i juste copy and past a short m2ts in the bdmv, with the windows explorer
keydb_helper
Post by keydb_helper » Thu Jul 03, 2025 11:12 am
Thanks for recreating the disc dump file. It is interesting that there is still no verification data...
Could you please make a protected backup of the disc with MakeMKV? After you have made the protected backup, please upload any small M2TS file from the BDMV/STREAM path and post the link here. Don't just copy a small file directly off the disc in case bus encryption is still active.
If there is no suitably small M2TS file, you can copy the first 2-4MB of the largest file with a tool such as dd or HxD and upload that instead.
jenrashe
Post by jenrashe » Thu Jul 03, 2025 1:46 pm
how can i do a protected backup with makemkv ?
Post by dcoke22 » Thu Jul 03, 2025 1:56 pm
On the first screen of MakeMKV, click the icon of the yellow folder with the green arrow. Make sure the decrypt box is unchecked.
MrPenguin
Post by MrPenguin » Thu Jul 03, 2025 2:17 pm
Alternatively, could you maybe install SamuriHL's utility and execute its "validate disc" function please? This should prove whether or not your disk's entry in KEYDB.cfg is correct.
jenrashe
Post by jenrashe » Thu Jul 03, 2025 3:08 pm
[(Disc Info)]
[Volume]: 2046
[Title]: 2046
[Date]: 2025-04-17
[MKB]: 82
[KEYDB_STATUS]: (NOTVALIDATED)
[STATUS]: complete
[DiscType]: UHD
Starting FindVUK validate disc!
MrPenguin
Post by MrPenguin » Thu Jul 03, 2025 3:23 pm
And yet your 00006.m2ts file plays in my browser just fine, and so is clearly successfully decrypted...?
Post by SamuriHL » Thu Jul 03, 2025 3:53 pm
This goes back to what keydb_helper said about the validation data. There appears to be an issue with it. As long as FindVUK validated it, it's fine.
jenrashe
Post by jenrashe » Thu Jul 03, 2025 3:59 pm
this is the file from the protected backup
https://drive.google.com/file/d/17X26Q6 ... sp=sharing
MrPenguin
Post by MrPenguin » Thu Jul 03, 2025 4:05 pm
This file also plays successfully. If it's from your protected back-up then it sounds as if your disk isn't encrypted! (Bus-encrypted only!)
jenrashe
Post by jenrashe » Thu Jul 03, 2025 4:11 pm
yes the file 7 is from the protected backup but i have always the errrors
18:09:12 - --- Write entry in backup-keydb file ---
18:09:12 - Keys in Keyfile: 2 keys - KeyFile: C:\Users\\Desktop\FindVUK\VUKbackup\KEYDB.cfg
18:09:12 - Disc with ID >64D2198531B536D03C16DDACADCB27B03DAF998E< is already in file - need to compare the details
18:09:12 - KEYDB: Identical entry already present in keydb-file
18:09:12 - >> Identical: TITLE, VUK, DATE, MEDIAKEY, VOLUMEID, UNITKEYS, COMMENT - Different: nothing >> will NOT write new entry in keydb-file
18:09:12 - Identical entry already present in keydb-file - file is not changed
18:09:12 - ERROR! Couldn't create BlurayMetaXML!
18:09:12 - ERROR! Couldn't upload entry to OnlineDB
18:09:12 - ERROR! Validate_UploadResultToOnlineDatabase failed!
18:09:12 - ERROR! ShowResult for mode ValidateDisc failed!
disc info :
[(Disc Info)]
[Volume]: 2046
[Title]: 2046
[Date]: 2025-04-17
[MKB]: 82
[STATUS]: complete
[DiscType]: UHD
18:10:26 - ERROR! Couldn't create BlurayMetaXML!
18:10:26 - ERROR! Couldn't upload entry to OnlineDB
18:10:26 - ERROR! Validate_UploadResultToOnlineDatabase failed!
18:10:26 - ERROR! ShowResult for mode ValidateDisc failed!
Validation complete!
