Fist of Fury 4K Arrow
FILIPINOY79
Seems like this disc is using a newer encryption. What do you guys need cause it seems like it takes forever to do anything after i try to open it with the program.
Re: Fist of Fury 4K Arrow
Taking forever to open usually means you need to clean the disc.FILIPINOY79 wrote: ↑Sat Jun 28, 2025 1:47 amSeems like this disc is using a newer encryption. What do you guys need cause it seems like it takes forever to do anything after i try to open it with the program.
If it's using a new AACS revision and can't decrypt it, it will say so in the log window.
FILIPINOY79
disc is brand new. and the last time i tried it was at 30 mins remaining. I'll try it again to see how long it will take.
FILIPINOY79
The disc is brand new, no scratches on the data side.
I'm attemping to run it through MakeMKV and it says 2 hours remaining. Here is what it's showing.
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'Re: Fist of Fury 4K Arrow
Are you sure LibreDrive is enabled? What does MakeMKV''s Info window say?FILIPINOY79 wrote: ↑Wed Jul 02, 2025 1:18 amI'm attemping to run it through MakeMKV and it says 2 hours remaining. Here is what it's showing.
MakeMKV v1.18.1 win(x64-release) started Using LibreDrive mode (v06.3 id=866A98CB9C4E) Using direct disc access mode Loaded content hash table, will verify integrity of M2TS files. Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
FILIPINOY79
