UHD FAQ
epletan
Re: UHD FAQ
Post by epletan » Tue Jul 01, 2025 8:13 am
Here the new file .tgz with AACS/MKB_RO.inf complete.
Don't hesitate to contact us if you need any other information.
Thank you for your work!
MrPenguin
Re: UHD FAQ
Post by MrPenguin » Tue Jul 01, 2025 12:21 pm
epletan wrote: Tue Jul 01, 2025 8:03 am Here is the requested file, missing from the previous .tgz, for the *Titanic 4K* UHD disc with the complete file MKB_RO.inf.
Thanks, but I don't see any file? Could you provide a download link please, if you cannot upload the file itself? (A MKB_RO.inf file is BIG, so you'd need to ZIP compress it first.)
epletan
Re: UHD FAQ
Post by epletan » Tue Jul 01, 2025 1:45 pm
MrPenguin wrote: Tue Jul 01, 2025 12:21 pm
The forum is showing me an error “Sorry, the board attachment quota has been reached”, so I’ll email it to you.
MrPenguin
Re: UHD FAQ
Post by MrPenguin » Tue Jul 01, 2025 1:52 pm
epletan wrote: Tue Jul 01, 2025 1:45 pm The forum is showing me an error “Sorry, the board attachment quota has been reached”, so I’ll email it to you.
You could still upload it to (say) OneDrive or Google Drive. Check PM?
Re: UHD FAQ
Post by SamuriHL » Sat Jul 05, 2025 3:45 pm
I released an updated KeyDB Helper version. It should be easier for people to set it up for MKB v82 decryption. It also has some internal bug fixing.
Cultural-Climate9187
Re: UHD FAQ
Post by Cultural-Climate9187 » Sat Jul 05, 2025 7:14 pm
I assume given my drive information any dumps need to go directly to MakeMKV since its a Pioneer?
Also what is so different about the two? technical answer or a heavily broken down answer would be appriciated very curious even when I may only understand like 34% of the explaination.
Re: UHD FAQ
Post by SamuriHL » Sat Jul 05, 2025 7:17 pm
I answered that in your other thread but I'll answer it here from the best of my understanding. Some Pioneer drives aren't able to provide the VID (Volume ID) for your disc. The VID is combined with an MK (Media Key) to create the VUK (Volume Unique Key). The VUK is then used by MakeMKV to decrypt the Unit Key(s) that decrypt the contents of your disc. Without being able to get the VID, the VUK can't be created. This is my understanding of the situation from what I've read by others.
Toad King
Re: UHD FAQ
Post by Toad King » Sat Jul 05, 2025 9:12 pm
SamuriHL wrote: Sat Jul 05, 2025 7:17 pm I answered that in your other thread but I'll answer it here from the best of my understanding. Some Pioneer drives aren't able to provide the VID (Volume ID) for your disc. The VID is combined with an MK (Media Key) to create the VUK (Volume Unique Key). The VUK is then used by MakeMKV to decrypt the Unit Key(s) that decrypt the contents of your disc. Without being able to get the VID, the VUK can't be created. This is my understanding of the situation from what I've read by others.
This is correct for AACS 1.0, but for AACS 2.0 on UHD discs there is more information needed beyond the VID. This info isn't publically in any dumps from any Pioneer drive, even ones with VIDs.
EDIT: Minor correction: It's in the Pioneer dumps but not in a format where the KeyDB can use it. Those have to be submitted to MakeMKV.
Re: UHD FAQ
Post by MartyMcNuts » Sun Jul 06, 2025 12:02 am
Cultural-Climate9187 wrote: Sat Jul 05, 2025 7:14 pm I assume given my drive information any dumps need to go directly to MakeMKV since its a Pioneer?
Yep, the process is to:
  • Always email the tgz dump file to svq@makemkv.com so a key can be derived and added to MakeMKV's hashed keys database.
  • If you want to help the community, you can also upload the tgz dump file somewhere like Onedrive or Googledrive etc then provide the download link in this thread: viewtopic.php?f=12&t=38293 along with a brief description, ie: the name of the disc, name of the dump file, the download link and maybe note what drive the dump was created with. This way, a key may also be derived and added to the public KeyDB database which MakeMKV (and other software) can use.
lm144
Re: UHD FAQ
Post by lm144 » Sun Jul 20, 2025 6:33 pm
Hi, thanks so much for creating this tool for us.
I also got a Pioneer drive (LibreDrive possible but not enabled). I have followed your steps but I got some hiccups. I wonder if you could offer some help?
I tried to put the config line with the MKBv82 device key from the doom9 post using the "Fix" button and this is what I have from the output:
Device key section not found.
[KeyDB Entry fix failed]
I have the keydb.cfg in the MakeMKV data folder.
I then manually added the MKBv82 device key and the host certificate (up to MKBv81) to the cfg file and tried to run "Disc Info".
A VID is returned, together with the DiscID and EncKey as well but it fails the obtain the Media Key.
Media Key: [NOT FOUND]
Media Key not found!
Does this have something to do with Pioneer? This is a very new title with MKB v82.
Thanks a lot :)
Re: UHD FAQ
Post by SamuriHL » Sun Jul 20, 2025 9:43 pm
Run the Synchronize function in the KeyDB Helper first. Then try the Fix function again to add the device key. The host cert, at least with my tool, is irrelevant and if you've put a v82 MKB disc in your drive it's irrelevant outside of my tool, as well as it's been revoked. But it didn't find the right section in the keydb.cfg to update with the device key. When I get time (won't likely be today as I'm working on other stuff for another project right now) I'll see if I can fix it so that doesn't happen. But once you do a synchronize it should have the proper headers added.
lm144
Re: UHD FAQ
Post by lm144 » Mon Jul 21, 2025 5:41 pm
SamuriHL wrote: Sun Jul 20, 2025 9:43 pm Run the Synchronize function in the KeyDB Helper first. Then try the Fix function again to add the device key. The host cert, at least with my tool, is irrelevant and if you've put a v82 MKB disc in your drive it's irrelevant outside of my tool, as well as it's been revoked. But it didn't find the right section in the keydb.cfg to update with the device key. When I get time (won't likely be today as I'm working on other stuff for another project right now) I'll see if I can fix it so that doesn't happen. But once you do a synchronize it should have the proper headers added.
Thanks for your help!
I don't really have a very good understanding of how things work but somehow it works today.
I deleted the keydb.cfg from the MakeMKV data folder and used the Synchronize function. After using the Fix function again, this time I got:
Device key added to keydb.cfg under the device key section.
I couldn't find the device key in the keydb.cfg but when I tried the Disc Info function, I was able to obtain the Media Key and VUK this time :o
Went back to MakeMKV and tried to rip the disc and this time I got the "download HK" message in the output box and it worked :)
Not really sure what happened but I wanted to know a bit more if you don't mind. FYI I sent the dump to the svq email yesterday (it is a Blu-ray MKBv82 title, not UHD). I wonder if it's because of the updated hashed keys? But probably not? Cause I could obtain the VUK with your tool before I ran MakeMKV... :?:
Re: UHD FAQ
Post by SamuriHL » Wed Jul 23, 2025 2:45 am
I just updated my tool. Add tool tips on the buttons, fixed the Fix function to work even if it's a brand new KeyDB.cfg file with no header, added a new Disc Hash function to content hash validate your disc, and sped up VID parsing slightly. Enjoy!
lm144
Re: UHD FAQ
Post by lm144 » Thu Jul 24, 2025 7:52 pm
SamuriHL wrote: Wed Jul 23, 2025 2:45 am I just updated my tool. Add tool tips on the buttons, fixed the Fix function to work even if it's a brand new KeyDB.cfg file with no header, added a new Disc Hash function to content hash validate your disc, and sped up VID parsing slightly. Enjoy!
Thanks again so much for your work.
I am trying to learn more about the whole AACS thing. Is there a possibility that the leaked device key gets into the drive revocation list and it can't be used for obtaining VUK of MKB v82 discs released in the future?
Toad King
Re: UHD FAQ
Post by Toad King » Thu Jul 24, 2025 10:18 pm
lm144 wrote: Thu Jul 24, 2025 7:52 pm
Device keys aren't revoked by the drive firmware, but by the MKB pressed on the disc. Only host keys get revoked by the drive.
