Babylon - Rausch der Ekstase (2022)
Platzhalter
Post by Platzhalter »
Dump submitted, MKB20_v77_Babylon_FF8D.tgz
MrPenguin
Re: Babylon - Rausch der Ekstase (2022)
Post by MrPenguin »
Platzhalter wrote:
Tue Jul 01, 2025 4:50 am
Could you also provide this dump file here please, e.g. by uploading it into (say) OneDrive or Google Drive, and then replying with a download link? This would allow people to try adding your disk to the public KEYDB.cfg file too.
Platzhalter
MrPenguin wrote:
Tue Jul 01, 2025 1:44 pm
Yeah. Here it is.
https://drive.google.com/file/d/1b_jrgn ... sp=sharing
MrPenguin
Post by MrPenguin »
Platzhalter wrote:
Wed Jul 02, 2025 5:22 pm
Yeah. Here it is.
Thanks for this :). Can you also provide the AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV.
Also, I see that you have created this TGZ dump file using a Pioneer BDR-UD04 (i.e. a Verbatim 43888?) drive. Would you also happen to have access to a non-Pioneer UHD drive please?
Platzhalter
MrPenguin wrote:
Thu Jul 03, 2025 11:25 am
Here you get the MKB_RO.inf.
https://drive.google.com/file/d/1aQ7_hP ... sp=sharing
Strange. Found the file i have sent via mail was a bit taller than the one i uploaded to google drive. But it seems it addianally only contains a firmware dump more. Anyway. I have reuploaded the first file.
Thanks for your patience. :D
Platzhalter
Sorry. No. I don't have access to another drive. And yes. The (Verbatim 43888 / FW 1.14) is exactly the drive i'm using.
