LG BH16NS40
Manyfold
Re: LG BH16NS40
Post by Manyfold » Sun Jun 29, 2025 6:55 pm
Jensen wrote: Fri Sep 09, 2022 4:07 pm I just bought the same drive and did some testing using Indiana Jones and the Raiders of the Lost Ark.
With HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin i get up around 15 read errors and the copy process is terminated.
With HL-DT-ST-BD-RE_BH16NS40-NS50-1.03-NM00000-211711201943.bin it works. I cross checked just to be sure:
1) Flash HL-DT-ST-BD-RE_BH16NS40-NS50-1.03-NM00000-211711201943.bin , get perfect copy, no errors.
2) Flash HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin, read error- no copy
3) Retry to copy - fail, read error.
4) Flash HL-DT-ST-BD-RE_BH16NS40-NS50-1.03-NM00000-211711201943.bin , get perfect copy again, no errors.
Before the try out, i cleaned the disk and after flashing the pc is is rebooted.
cpu is ryzen 5950x, 32gig ram 3600mhz and msi meg x570S ace max mb.
Im pretty sure my test is accurate and that HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin is bad for BH16NS40 with 1.05 firmware stock.
Other than that , MakeMKV and the tools u guys provide is absolutely gold, amazing work.
Thank you very much. Such hints are always appreciated.
However, in this case, I couldn't notice any change in behavior. I have a BH16NS40 and had installed HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin from the beginning on. Recently I have bought some more BRs and now wanted to backup them (normal Blu-Rays, not 4K).
One of them even is not recognized by the drive. The drive chews on it for two minutes or so and then reports that no disc is inserted. Another of the discs can't be copied by MakeMKV because there is a lot of SCSI errors quite at the beginning of the process. The rest of the discs behaves as expected.
To solve the problem, I have followed your suggestion and have installed HL-DT-ST-BD-RE_BH16NS40-NS50-1.03-NM00000-211711201943.bin. But this did not change anything. So I have installed the previous firmware again.
Probably those two discs are really defective, although I'm asking myself how this can be the case. I'll return them to the seller.
Re: LG BH16NS40
Post by MartyMcNuts » Mon Jun 30, 2025 12:18 am
Manyfold wrote: Sun Jun 29, 2025 6:55 pm
Firmware is not the issue. Clean the discs and try again. Possibly defective. LG internal drives are pretty crappy these days. QC went downhill around 2020.
zittrig
Re: LG BH16NS40
Post by zittrig » Mon Jun 30, 2025 5:55 am
You can also try to clean the laser lenses.
Do it with q-tip and alcohol (Isopropanol). Clean twice and dry immediately also with q-tip or a lint-free cloth.
Re: LG BH16NS40
Post by Coopervid » Mon Jun 30, 2025 9:39 am
Generally the WH16NS60 1.02 firmware works best for 5,25" LG-type drives, especially if it's a 3-layer disc (>66GB).
Always wash UHD discs before ripping!
Laser lens cleaning might also help.
If all still fails get a Pioneer drive as long as they are available. Preferrably with firmware before Dec. 2022 (see seller section).
Manyfold
Re: LG BH16NS40
Post by Manyfold » Mon Jun 30, 2025 9:10 pm
@Coopervid @zittrig @MartyMcNuts
Thanks a lot! I didn't expect such fast answers given that the thread was quite old and dead for a while.
I'll follow your advice and try to clean the laser lens. I wouldn't have thought that this is important, but it sounds logical. I guess cleaning the discs wouldn't effect anything, because I have carefully examined them using a strong light source and a magnifier and didn't notice something suspicious.
I am ready to buy a new drive from whatever manufacturer is recommended :-) That would probably be a good idea anyway. I'll look into the seller section and see if somebody is willing to ship the preferred model to Europe.
I should soon (during this week) get a replacement for one of the defective discs (the one that the drive recognizes but then produces errors with). In every case, I'll try that replacement disc with the current drive. Since there seems to be interest for this subject, I'll report back.
Manyfold
Re: LG BH16NS40
Post by Manyfold » Wed Jul 02, 2025 5:36 pm
I now have got the first of the replacement discs (the one that the drive recognized, but could not read). It was indeed the disc that was defective. The drive could read the replacement disc without any issue.
Unfortunately, the other disc will take longer to be replaced. Again, I'll report back when it has happened and when I have tested it.
Re: LG BH16NS40
Post by Coopervid » Wed Jul 02, 2025 8:07 pm
Woodstock wrote: Fri Dec 16, 2022 11:28 pm Since no drive built prior to 2015 could POSSIBLY read a UHD, a drive from 2012 is "right out".
A different, newer drive is required.
No LG drive. Pioneers can.
Manyfold
Re: LG BH16NS40
Post by Manyfold » Wed Jul 09, 2025 5:20 pm
So today I've got the replacement for the other disc (the disc the drive chew on for one or two minutes without recognizing it).
Unfortunately, the drive is failing with the new disc in the same way. I am now convinced that this type of drive simply cannot read this disc. I have tested a dozens of other discs in the meantime which the drive could all read without any problem, so the drive is OK. It's just that special disc that it is not compatible with.
I am unsure how I should proceed now. Any ideas? Any other firmware that's promising?
Re: LG BH16NS40
Post by Coopervid » Wed Jul 09, 2025 6:42 pm
Manyfold wrote: Wed Jul 09, 2025 5:20 pm So today I've got the replacement for the other disc (the disc the drive chew on for one or two minutes without recognizing it).
A Pioneer drive if you still can get one.
Re: LG BH16NS40
Post by MartyMcNuts » Wed Jul 09, 2025 11:14 pm
Firmware won't help. Get another drive. Some drive's just don't like some discs. It's as simple as that.
asmcom
Re: LG BH16NS40
Post by asmcom » Fri Jul 11, 2025 9:47 pm
Coopervid wrote: Wed Jul 09, 2025 6:42 pm
We still have plenty of Pioneer drives. Our website opens on Wednesday 23rd July 2025.
go.uhdfriendlydrives.co.uk
Kind Regards
Asmcom :mrgreen:
Manyfold
Re: LG BH16NS40
Post by Manyfold » Sat Jul 12, 2025 9:00 pm
@asmcom
Thank you very much for your reply. I have seen that your website has been closed for two weeks, and I am afraid that the Pioneers will be out of stock when it is reopened. I really hope that I can get one or two of them when you return from vacation. Do you have internal 5.25 drives in stock as well? I could live with the external ones, but would prefer the internal SATA variant (of course only unless the external drives work better in some way).
asmcom
Re: LG BH16NS40
Post by asmcom » Sun Jul 13, 2025 10:44 am
Manyfold wrote: Sat Jul 12, 2025 9:00 pm @asmcom
We currently have only 395 internal Pioneer drives left in stock, and they're selling rapidly. At this pace, we expect them to be sold out within ten days when we reopen on the 23rd July 2025 at 8:00 AM (UK time).
Asmcom :mrgreen:
Manyfold
Re: LG BH16NS40
Post by Manyfold » Sun Jul 13, 2025 8:54 pm
asmcom wrote: Sun Jul 13, 2025 10:44 am
Asmcom :mrgreen:
Thank you very much. I have already entered an appropriate task into my electronic calendar :D
Since you have a lot of experience in this field: Would you say that the external drives are more reliable than the internal ones, or vice versa? Which of the drives you have in stock would you recommend the most (taking both internal and external drives into account), given that I won't use the drive for writing, and given that I'll reserve the drive exclusively for backing up discs (that is, to reduce wear, I won't use it for normally watching movies on disc)?
SirNasso
Re: LG BH16NS40
Post by SirNasso » Tue Sep 23, 2025 8:24 am
Sory for bumping an old thread, but I just the same model.
MakeMKV shows this:
OS device name: F:
Product: BD-RE BH16NS40
Revision: 1.00
Serial number:
Firmware date: 2112-10-31 19:17
Drive platform: MT1939
Firmware version: 1.00
BD raw metadata read: Partial
So can you advise on which firmware should I update to?
Thank you in advance!
