KEYdb loki sison 2 et Andor
Dj-pioupiou
Post by Dj-pioupiou »
Français :
Salut,
Cela fait plusieurs semaines que j’essaie de faire un remix de ces deux séries, mais je n’y parviens pas.
Même en récupérant la base de clés (keydb) depuis le site http://fvonline-db.bplaced.net/, cela ne fonctionne pas.
Les séries y sont bien répertoriées, mais les clés semblent inopérantes.
Quelqu’un aurait-il les clés correctes à ajouter ?
English:
I’ve been trying for several weeks to make a remix of these two series, but I haven’t succeeded.
Even after downloading the key database (keydb) from http://fvonline-db.bplaced.net/, it still doesn’t work.
The series are listed there, but the keys don’t seem to function.
Does anyone have the correct keys to add?
MrPenguin
Re: KEYdb loki sison 2 et Andor
Post by MrPenguin »
Dj-pioupiou wrote:
Sun Jun 29, 2025 3:35 pm
You probably have variants of these disks that no-one else has contributed yet. Has MakeMKV generated TGZ dump files for any of these disks? If so, you need to email them to svq@makemkv.com. However, if you're interested in contributing to the public KEYDB database then could you also make these TGZ dump files available here please? Ideally, by uploading them all into (say) OneDrive or GoogleDrive, and then replying here with the download links.
See the Public KEYDB Disc Submissions thread.
Dj-pioupiou
je ne sait pas ou envoyer les informatuin du disque
Getting disc info...
Validation Data: 0DA9E2E59D54998190B58EAF5E8EEB14 [FOUND]
Media Key: B6C74EAF642632BAE4FDE1D3393D0672 [VALID]
VUK: AE2C0E01BA2B4EBE1EDCC61BD862FB5D [VALID]
Encrypted Unit Key: 2240421CC37EA6E4F97E27BCDDC07A0E [FOUND]
Decrypted Unit Key: 99DDB0D7921BE7510492F93FA5032D3F [FOUND]
Unit Key(s) tested with 3 aligned units : [VALIDATED]
[(Disc Info)]
[DiscID]: 0xDE40B35FC6A47DB99B17D72CC9FE3E5E1DB963E6
[Volume]: MARVEL_STUDIOS_LOKI_S2_D2
[Title]: MARVEL STUDIOS' LOKI SEASON 2 DISC 2 - Ultra HD™
[Date]: 2024-10-18
[MediaKey]: 0xB6C74EAF642632BAE4FDE1D3393D0672
[VID]: 0xF122E51D35537A7DAF833B9389B24D92
[VUK]: 0xAE2C0E01BA2B4EBE1EDCC61BD862FB5D
[MKB]: 77
[UnitKey]: 1-0x99DDB0D7921BE7510492F93FA5032D3F
[KEYDB_STATUS]: (VALIDATED)
[STATUS]: complete
[DiscType]: UHD
MrPenguin
Post by MrPenguin »
Dj-pioupiou wrote:
Mon Jun 30, 2025 10:57 am
[(Disc Info)]
[Date]: 2024-10-18
[MKB]: 77
[STATUS]: complete
[DiscType]: UHD
The latest KEYDB.cfg file already contains an entry for this disk. Just download this file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
