BH16NS40 back to original firmware possible?
misfits73
Post by misfits73 » Sat Jun 28, 2025 1:13 pm
I have a BH16NS40 flashed with WH16NS60_1.02_MK firmware.
Of course it's listed a a WH16NS60 and never had a problem with whatever i threw in.
Now I want to sell it so i was wondering if there is a way to go back to BH16NS40 with 1.01 firmware that came with when i purchased it, so the seller will get exactly what's shown on the product tag.
Browsing at the forum but no luck
Could someone help?
Re: BH16NS40 back to original firmware possible?
Post by Coopervid » Sat Jun 28, 2025 9:05 pm
Could someone help?
This is counterproductive.
misfits73
Post by misfits73 » Sat Jun 28, 2025 9:19 pm
Thanks for your reply.
I'll be clear with the buyer, if he wants to flash it again for the sleep bug etc that's fine.
I just want to sell a BH16NS40, not a WH16NS60
Can you help?
asmcom
Post by asmcom » Sat Jun 28, 2025 9:56 pm
Could someone help?
Yes of course you can flash back to stock if you want to sell or upgrade. I can see why coopervid finds this counter productive. Why would you not sell the drive on the firmware it is on? WH16NS60_1.02_MK is the best firmware for this drive.
If you really want to take a backward step. Just flash to this firmware
HL-DT-ST-BD-RE_BH16NS40-NS50-1.05-NM00600-212005061331
Can be found here. Look under MK directory.
https://www.makemkv.com/download/mk-fir ... 200720.zip
5_mk-firmware-pack-20th July 2020/MK/HL-DT-ST/BH16NS40-NS50
Ensure the drive is an LG model with the SVC code NS50 and was manufactured after 2015. The drive platform should be MT1959 and you flash at your own risk. If you want to be safe contact Billycarr11 or martmcnuts both the number 1 for flashing drives on this forum.
Kind Regards
Asmcom
Billycarr11
viewtopic.php?t=17831
Martymcnuts
viewtopic.php?t=18747
Post by MartyMcNuts » Sun Jun 29, 2025 12:30 am
Could someone help?
No point in going back to stock firmware. Just tell the buyer it is already flashed for UHD compatibility and is ready to go!
misfits73
Post by misfits73 » Mon Jul 07, 2025 11:01 pm
Thank you all for your help
