AACS v82 decrypt failure: dump attached
spinout
Post by spinout »
Hello, long time user. Very recently released Blu-ray disc can't be decrypted from AACS v82. Dump file attached. Just updated to MakeMKV 1.18.1.
Also oddly am getting the following error while attempting to open the disc:
Downloading latest HK to /Users/<mylogin>/Library/MakeMKV ...
Do I need to do/check something to enable auto HK downloading; is the message indicating a problem? I checked in my Library/MakeMKV folder and there is no keys.cfg or similar file there. Internet access for online updates is enabled.
MKB_v82_Pink_Floyd_at_Pompeii_B8B8.tgz
(114.04 KiB) Downloaded 222 times
MrPenguin
Re: AACS v82 decrypt failure: dump attached
Post by MrPenguin »
spinout wrote: Sat Jun 28, 2025 6:37 pm Do I need to do/check something to enable auto HK downloading; is the message indicating a problem? I checked in my Library/MakeMKV folder and there is no keys.cfg or similar file there. Internet access for online updates is enabled.
spinout
[Solved] Re: AACS v82 decrypt failure: dump attached
Post by spinout »
MrPenguin wrote: Sat Jun 28, 2025 6:46 pm Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
Thank you MrPenguin -- that solved it for me and the Blu-ray is copying successfully.
