Fist of Fury 4K Arrow
FILIPINOY79
Post by FILIPINOY79 » Sat Jun 28, 2025 1:47 am
Seems like this disc is using a newer encryption. What do you guys need cause it seems like it takes forever to do anything after i try to open it with the program.
Re: Fist of Fury 4K Arrow
Post by MartyMcNuts » Sat Jun 28, 2025 2:42 am
FILIPINOY79 wrote: Sat Jun 28, 2025 1:47 am Seems like this disc is using a newer encryption. What do you guys need cause it seems like it takes forever to do anything after i try to open it with the program.
Taking forever to open usually means you need to clean the disc.
If it's using a new AACS revision and can't decrypt it, it will say so in the log window.
FILIPINOY79
Post by FILIPINOY79 » Wed Jul 02, 2025 12:25 am
disc is brand new. and the last time i tried it was at 30 mins remaining. I'll try it again to see how long it will take.
FILIPINOY79
Post by FILIPINOY79 » Wed Jul 02, 2025 1:18 am
The disc is brand new, no scratches on the data side.
I'm attemping to run it through MakeMKV and it says 2 hours remaining. Here is what it's showing.
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
MrPenguin
Post by MrPenguin » Wed Jul 02, 2025 11:09 am
FILIPINOY79 wrote: Wed Jul 02, 2025 1:18 am I'm attemping to run it through MakeMKV and it says 2 hours remaining. Here is what it's showing.
Are you sure LibreDrive is enabled? What does MakeMKV''s Info window say?
FILIPINOY79
Post by FILIPINOY79 » Thu Jul 03, 2025 3:16 am
Here you go
FILIPINOY79
Post by FILIPINOY79 » Thu Jul 03, 2025 3:19 am
